Label | Description |
A | Click to hide or show the contents menu and Index. |
B | This shows a menu of the content topics. Click a topic heading to display its content in the main screen. |
C | Click this to show the Index panel. Click an index entry to view its description. |
D | Enter a keyword to search and display the related section(s) in the online document. |
E | These are the navigation buttons. • Click the Previous button to display the previous chapter in the online document. • Click the Next button to display the next chapter in the online document. • Click the Home button to display the first chapter in the online document. |
F | Click this to view the translated content page. You can click Google Translate anywhere in a content page, but you must be at the top of the content page to choose a language. The bottom right of the content page has a ‘Back to top’ arrow to get there. |
G | Click this to download content in a PDF file. You must be at the top of the content page to click the PDF icon. |
H | The content of the online document is displayed here. |
service | fqdn | ip address | port | protocol |
Nebula Cloud Management (NETCONF) | d.nebula.zyxel.com | 34.247.112.130, 52.210.12.1, 52.48.115.44, 54.73.103.137, 63.32.141.172, 63.35.107.114 | 4335 / 6667 | TCP |
Nebula Cloud Management | s.nebula.zyxel.com | Dynamic | 443 | TCP |
Network Time Protocol | *.pool.ntp.org | Dynamic | 123 | UDP |
Nebula Cloud Management (Zero Touch Provisioning) | d-a.nebula.zyxel.com | Dynamic | 443 | TCP |
Nebula Cloud Management (Configure related service for USG FLEX series) | d-cp.nebula.zyxel.com | 34.254.181.105, 52.212.114.133 | 4335 | TCP |
Nebula Cloud Management (Monitor related service for USG FLEX series) | d-mp.nebula.zyxel.com | 52.18.204.70, 54.220.154.85, 63.34.155.16 | 443 | TCP |
Zyxel Support Access Invite Zyxel support as administrator | Select ON to allow the Zyxel customer support account to access your organization temporarily, so that they can help check your configurations and log messages. At the time of writing, the support account will be deactivated automatically after 21 days. You can set the number of days, or select Never. If you select ON, you can click here to change the support account’s name and access right to the organization and sites. |
My Cases | |
![]() | Click this button to reload the data-related frames for this section on the page. |
Open/Closed | Select to view the details about the tickets that are still open or closed. |
Case Number | This shows the number of the eITS ticket. |
Created | This shows the first date and time the ticket was created. |
Last Updated | This shows the last date and time the ticket was updated. |
Creator | This shows the account name of the administrator that created this ticket. |
Subject | This shows the subject of the ticket. |
Priority | This shows the severity level of the ticket. |
Status | This shows whether the ticket is open or closed. |
Engineer | This shows the name of the support person who handles the ticket. |
New Case | Click this button if you want to issue a new ticket. The following fields then appear allowing you to provide the necessary information and describe the issue encountered. |
Subject | Enter the subject of the ticket. |
Carbon Copy (CC) | Enter the email address of the person you would like to receive a copy of the case. |
Device | Select the NCC or the name of the Nebula Device that cannot work properly. |
Issue Description | Enter a complete and detailed description of your issue. |
Priority | Select the severity level of the ticket. Click the Definition of priority link to see how to correctly identify a ticket’s severity level. This can help to get your problem solved quickly. |
Add Another File | Click this button to upload another file. |
Choose File/Browse... | Click this button to locate the file you want to upload for reference. |
Delete | Click this button to remove the file you just uploaded before submitting the ticket. |
Cancel | Click this button to close the New Case section without saving. |
Submit | Click this button to send your ticket to the Zyxel customer support. |
