Summary Report
This screen displays network statistics for Nebula Devices of the selected site, such as bandwidth usage, top ports and/or top Nebula Devices.
Click Switch > Monitor > Summary Report to access this screen.
Label
Description
Switch – Summary report
Select to view the report for the past day, week or month. Alternatively, select Custom range... to specify a time period the report will span. You can also select the number of results you want to view in a table.
Email report
Click this button to send summary reports by email, change the logo and set email schedules.
Consumption
Total
This shows the total power consumption of the Nebula Device ports.
Current Consumption
This shows the current power consumption of the Nebula Device ports.
Max Consumption
This shows the maximum power consumption of the Nebula Device ports.
Min Consumption
This shows the minimum power consumption of the Nebula Device ports.
y-axis
The y-axis shows how much power is used in Watts.
x-axis
The x-axis shows the time period over which the power consumption is recorded.
Top power consumption
This shows the ranking of the Nebula Device.
Name
This shows the descriptive name of the Nebula Device.
Model
This shows the model number of the Nebula Device.
Power Usage
This shows the total amount of power consumed by the Nebula Device’s connected PoE devices during the specified period of time.
Peak Power
Name
Model
Max Power
This shows the maximum power consumption for the Nebula Device’s connected PoE devices during the specified period of time.
Power %
This shows what percentage of the Nebula Device’s total power budget has been consumed by connected PoE powered devices.
Top uplink port
Name
Model
Usage
This shows the amount of data that has been transmitted through the Nebula Device’s uplink port.
Top port
This shows the ranking of the Nebula Device port.
Name
Port
This shows the port number on the Nebula Device.
Model
Usage
This shows the amount of data that has been transmitted through the Nebula Device’s port.
Location
This shows the location of the Nebula Devices on the map.
