Surveillance Port Details
Use this screen to view detailed information about a port on the Surveillance screen.
Go to Switch > Monitor > Surveillance and click on a value in the Discovered Devices column to access this screen.
Switch > Monitor > Surveillance > Port Details
Label
Description
Status
Link speed
This shows the speed (either 10M for 10 Mbps, 100M for 100 Mbps, or 1G for 1 Gbps) and the duplex (F for full duplex or H for half). This field displays Down if the port is not connected to any device.
PoE draw
This shows the total power that the connected PD draws from the port, in watts. This allows you to plan and use within the power budget of the Nebula Device.
PD health
This shows the status of auto PD recovery on this port.
Red: The Nebula Device failed to get information from the PD connected to the port using LLDP, or the connected PD did not respond to the Nebula Device’s ping requests.
Yellow: The Nebula Device is restarting the connected PD by turning the power off and turning it on again.
Green: The Nebula Device successfully discovered the connected PD using LLDP or ping.
--: Auto PD Recovery is not enabled on the Nebula Device and/or the port, or the Nebula Device is not supplying power to the connected PD.
For details on configuring auto PD recovery on a port, see Switch Ports.
Extended range
This shows whether extended range is enabled on the port.
Bandwidth Tx/Rx (%)
Tx shows the number of kilobytes per second transmitted on this port. Rx shows the number of kilobytes per second received on this port.
CRC
This shows the number of packets received with CRC (Cyclic Redundant Check) errors.
Power cycle
Click Reset to power off the PD connected to the port, by temporarily disabling then re-enabling PoE.
Neighbor detail
This section shows all clients connected to the port.
Search clients
Search for one or more clients in the list by keyword, status, system name, port, IP address, or firmware version.
clients
This shows the number of clients connected to this port.
Flush
Click this to remove all offline clients from the list.
Status
This shows whether the client is online (green) or offline (red), and whether the client is wired or wireless.
System name
This displays the system name of the Nebula Device.
Port
This displays the number of the Nebula Device port that is connected to the Nebula Device.
IP
This shows the IP address of the Nebula Device.
Firmware
This shows the firmware version currently installed on the Nebula Device.
Description
This shows the descriptive name of the Nebula Device.
