Monitor Dynamic VLAN Using Event Logs (for Nebula Switches only)
Go to Switch > Monitor > Event log to monitor dynamic VLANs. The following are example dynamic VLAN-related event logs:
User submits an incorrect 802.1X credential (wrong user name on the client port ‘Port4’).
The dynamic VLAN attribute received is without a corresponding static VLAN (missing static VLAN 10 for the user name ‘vlan10’ on the client port ‘Port4’).
The Nebula Device cannot connect with an external RADIUS server.
The Nebula Device re-establishes connection with an external RADIUS server.
