Activate and Assign a License for a Nebula Device, Site, or Organization
This section shows you how to activate and assign a license for a Nebula Device, site, or organization. See
Organization License Tiers for a summary of NCC licenses.
The following table describes the license types at the time of writing.
License Types
Location | license type | application |
MSP (Managed Services Provider) | MSP | NCC (Nebula Control Center) user account |
Organization-wide | PRO / PLUS | AP (Access Point) / NSG (Nebula Security Gateway) / Switch / USG FLEX device |
Organization-wide | Gold Security | ATP device |
Site-wide | NSS (Nebula Security Service) | NSG device |
Site-wide | UTM (Unified Threat Management) Security / Secure WiFi | USG FLEX device |
Site-wide | Content Filter | USG FLEX 50 / USG20-VPN / USG20W-VPN device |
Site-wide | Connect & Protect (CNP) / Connect & Protect Plus (CNP+) | NWA1123ACv3, WAC500, WAC500H / NWA110AX, NWA210AX, WAX510D, WAX610D, WAX630S, WAX650S device |
Bundled License and Add-on License
A bundled license is a license that is included when you purchase a Nebula Device (Mobile Router, Access Point, Switch, NSG, USG FLEX, ATP, and USG20(W)-VPN). The bundled license is automatically assigned to the purchased Nebula Device when you add the Nebula Device to NCC. A bundled license cannot be transferred to another Nebula Device.
An add-on license is a license purchased separately from a Nebula Device as a license key, from Zyxel or another vendor. An add-on license can be applied to any Nebula Device.
License States
The following are the license states in NCC.
• Active – the license pack is assigned to a Nebula Device, is activated, and is in use (expiration countdown/timer has started).
• Queued – the license pack is assigned to a Nebula Device, is activated, but not yet in use.
• Inactive – the license pack is assigned to a Nebula Device, but is not yet activated in NCC.
• Unused – The license pack is assigned to an organization, but is not yet assigned to a Nebula Device and not yet activated in NCC.
License Activation Process
You must have a Nebula Device and a license pack to activate a license. Perform the following to activate a license.
1 In the Organization-wide > Configure > License & inventory, click Action > Add more licenses.
2 Enter the License key and the License information will display.
3 Click Finish. The license is now assigned to your organization and site.
A newly assigned license will not start its expiration countdown/timer until activated. Multiple add-on Plus Pack and Pro Pack licenses can be assigned to the same Nebula Device managed by
NCC.4 In the Organization-wide > Configure > License & inventory, select the Devices tab.
5 Locate the Nebula Device to assign a license(s). Click the Actions button and select Assign license on the device row.
6 Clear any license that you do not want added to the Nebula Device.
7 For multiple licenses of the same type to be added to the Nebula Device, set the number of licenses in the Select # of license field.
8 Set the expected expiration date criteria from the License assignment mode.
• Assign min. period – NCC assigns one of each license type with the shortest duration to each Nebula Devices.
• Assign all – NCC assigns all selected license type equally to each Nebula Device.
• Target expiration date – Set a future date. NCC assigns an equal number of licenses to each Nebula Devices until the expiration date (future date) is reached or exceeded.
9 Click Please check this box if you want to activate licenses and upgrade. Then, click Finish.
The features that will be unlocked depends on the license type purchased.
