Label | Description |
+ Create | Click this button to add a new alert template (see Alert Settings). |
Delete | Click this button to remove alert templates already created. |
Search | Specify your desired search criteria to filter the list of alerts. |
selected in | This shows the number of alerts that match your filter criteria after you perform a search. |
Template | This shows the number of alert templates you have created. |
Name | This shows a descriptive name of the alert template. |
Description | This shows more details on the alert template. |
Creator | This shows your email address. |
Bound organizations | This shows All organizations or a list of the selected organizations to send alerts to. |
Exclude sites | This shows the sites that will not receive any alerts. |
Enable | Click this to activate the alert template. |
General | |
Template name | Enter a descriptive name for the alert template (up to 64 alphanumeric characters including spaces). |
Description | Enter more details of the alert template (up to 64 alphanumeric characters including spaces). |
Email recipient | Enter the email addresses to which you want to send alerts. ![]() For example, ORG 1 is a Base tier organization, and ORG 2 is a Professional tier organization. An MSP alert template is created to monitor AP offline events. If there are three email recipients in both ORG 1 and ORG 2 with the following licenses: • REP 1 (recipient 1) has an account which includes an MSP license. • REP 2 (recipient 2)and REP 3 (recipient 3) has accounts which does not include an MSP license. When an AP offline event occurs, an email alert will only be sent to REP 1 in ORG 1. While an email alert will be sent to all recipients (REP 1, REP 2, and REP 3) in ORG 2. |
Apply to | Select All organizations or specify the selected organizations to send alerts to. |
Exclude sites | Select the sites in organizations that will not receive any alerts. |
System alerts | |
Notification Type | For each alert, you can set how to receive alert notifications: • Email: Alert notifications are sent by email to configured recipients. • In-app Push: Alert notifications are sent to site administrators who are logged into the Nebula Mobile app. This type of notification is not available for some features. • Both: Alert notifications are sent by email and app notification. • Disabled: No alerts are sent. |
Show additional recipients | Add additional user accounts who will receive email and in-app notifications for the alert. |
System Alerts | |
Wireless | Specify how long in minutes the NCC waits before generating and sending an alert when an access point goes offline. |
Switches | Specify how long in minutes the NCC waits before generating and sending an alert when a port or a switch goes offline. |
Security gateway | Specify how long in minutes the NCC waits before generating and sending an alert when the following events occur: • A gateway device goes offline. • Any DHCP pool on the gateway device runs out of IP addresses to assign. • A VPN connection to or from the gateway device is created or terminated. • The WAN connectivity goes offline. |
Mobile router | Specify how long in minutes the NCC waits before generating and sending an alert when an mobile router goes offline. |
Other | Specify whether to send an alert each time configuration settings are changed. |
Security alerts | |
CDR containment | Specify whether to send an alert each time a CDR block or containment action is triggered. |
SecuReporter | |
Notification mode | Select whether to receive email security reports from SecuReporter. |
Email subject | Enter an email title here. |
Email description | Enter a description of the emails to be sent here. For example, maybe these emails are just for high severity events. |
Notification interval | Specify how often to receive a SecuReporter report. If no security events were triggered, SecuReporter will not send a report. |
Event severity | Select the severity level of events that will be included in each report. |
Event threshold | This table lists the events that trigger SecuReporter security alerts. You can set the alert threshold. For example, X count(s) of malware/virus attack within 5 minutes means SecuReporter includes a report in the email if the total number of combined malware and virus detection events exceed X within a 5 minute time period. |
