Logins
Set Up Login Accounts
Up to five people (one administrator and four non-administrators) may access the Switch through Web Configurator at any one time.
• An administrator is someone who can both view and configure Switch changes. The user name for the Administrator is always admin. The default administrator password is 1234.
*It is highly recommended that you change the default administrator password (1234).
• A non-administrator (user name is something other than admin) is someone who can view and/or configure Switch settings. The configuration right varies depending on the user’s privilege level.
Click SYSTEM> Logins to view the screen as shown.
SYSTEM > Logins
*The input string in any field of this screen should not contain [ ? ], [ | ], [ ' ], [ " ] or [ , ].
In the Password fields, [ space ] is also not allowed.
SYSTEM > Logins
LABEL
Description
Administrator
This is the default administrator account with the “admin” user name. You can change the default administrator user name.
User Name
Change the default “admin” system user name (up to 32 printable ASCII characters except [ ? ], [ | ], [ ' ], [ " ], [ space ], [ , ], or [ : ].
Old Password
Enter the existing system password (1234 is the default password).
New Password
Enter your new system password. You can enter up to 32 printable ASCII characters.
Retype to confirm
Retype your new system password for confirmation. You can enter up to 32 printable ASCII characters.
Edit Logins
You may configure passwords for up to four users. These users can have read-only access.
Login
This is the index of an user account.
User Name
Set a user name (up to 32 printable ASCII characters except [ ? ], [ | ], [ ' ], [ " ], or [ , ]).
Password
Retype to confirm
Privilege
Type the privilege level for this user. At the time of writing, users may have a privilege level of 0, 3, 13, or 14 representing different configuration rights as shown below.
• 0 – Display basic system information.
• 3 – Display configuration or status.
• 13 – Configure features except for login accounts, SNMP user accounts, the authentication method sequence and authorization settings, multiple logins, administrator and enable passwords, and configuration information display.
• 14 – Configure login accounts, SNMP user accounts, the authentication method sequence and authorization settings, multiple logins, and administrator and enable passwords, and display configuration information.
Users can run command lines if the session’s privilege level is greater than or equal to the command’s privilege level. The session privilege initially comes from the privilege of the login account. For example, if the user has a privilege of 5, he or she can run commands that requires privilege level of 5 or less but not more.
Apply
Cancel
