Group Portal
The overview screen allows you to view the status of organizations in a group. Click Group-wide > Group-wide manage > Group portal to access this screen.
Label
Description
Search
Specify your desired filter criteria to filter the list of organizations.
matches in
This shows the number of organizations that match your filter criteria after you perform a search.
N Organizations
This shows the number of organizations (N) tin the group.
Status
This shows the status of Nebula Devices in the organization.
Green: All Nebula Devices are online and have no alerts.
Amber: One or more Nebula Devices have alerts.
Red: One or more Nebula Devices are offline.
Gray: All Nebula Devices have been offline for 7 days or more.
White: No Nebula Devices.
Organization
This shows the descriptive name of the organization.
Type
This shows the NCC license type of the organization.
NCC License Status
This shows whether the license is valid (OK), the license has expired and the organization downgraded from NCC Pro or Plus Pack to the base tier (Expired), or this is a free organization and an NCC license is not required (N/A).
Payment mode
This shows the payment method of the organization’s license if you arranged a special payment method with Zyxel.
If you bought the license through the Zyxel web store or a third-party vendor, the value will be blank.
NCC License expiration (UTC)
This shows the date when the license will expire, or N/A when there are no Nebula Devices in the organization or if this is a free organization and an NCC license is not required.
Sites
This shows the number of sites belonging to this organization.
Devices
This shows the number of Nebula Devices in the organization that have one of the following status:
Green: The Nebula Device is online and has no alerts.
Amber: The Nebula Device has alerts.
Red: The Nebula Device has been offline for less than 7 days.
Gray: The Nebula Device has been offline for 7 days or more.
AP
This shows the number of Nebula Access Points in the organization.
SW
This shows the number of Nebula Switches in the organization.
SA
This shows the number of NSG and USG FLEX, ATP series, and USG20(W)-VPN Security Appliances connected to the sites in this organization.
