Support Request
If you need Zyxel customer support to help you find answers and/or solve problems, you can submit a ticket through the NCC.
*It is suggested that you check this user’s guide first to seek help and then go to the Zyxel Nebula Community before you use this screen to send a ticket.
Click Help > Still need help? > Support request to access this screen. The screen varies depending on whether you select to view the ticket details or create a new ticket.
*Direct Support for opening a ticket to get direct assistance from the Nebula technical support team is only available for Nebula Pro Pack license.
Help > Still need help?: Support request
Help > Still need help?: Support Request
Label
Description
Zyxel Support Access
Invite Zyxel support as administrator
Select ON to allow the Zyxel customer support account to access your organization temporarily, so that they can help check your configurations and log messages. At the time of writing, the support account will be deactivated automatically after 21 days. You can set the number of days, or select Never.
If you select ON, you can click here to change the support account’s name and access right to the organization and sites.
My Cases
Click this button to reload the data-related frames for this section on the page.
Open/Closed
Select to view the details about the tickets that are still open or closed.
Case Number
This shows the number of the eITS ticket.
Created
This shows the first date and time the ticket was created.
Last Updated
This shows the last date and time the ticket was updated.
Creator
This shows the account name of the administrator that created this ticket.
Subject
This shows the subject of the ticket.
Priority
This shows the severity level of the ticket.
Status
This shows whether the ticket is open or closed.
Engineer
This shows the name of the support person who handles the ticket.
New Case
Click this button if you want to issue a new ticket. The following fields then appear allowing you to provide the necessary information and describe the issue encountered.
Subject
Enter the subject of the ticket.
Carbon Copy (CC)
Enter the email address of the person you would like to receive a copy of the case.
Device
Select the NCC or the name of the Nebula Device that cannot work properly.
Issue Description
Enter a complete and detailed description of your issue.
Priority
Select the severity level of the ticket. Click the Definition of priority link to see how to correctly identify a ticket’s severity level. This can help to get your problem solved quickly.
Add Another File
Click this button to upload another file.
Choose File/Browse...
Click this button to locate the file you want to upload for reference.
Delete
Click this button to remove the file you just uploaded before submitting the ticket.
Cancel
Click this button to close the New Case section without saving.
Submit
Click this button to send your ticket to the Zyxel customer support.
