Label | Description |
APs status | This shows the number of assigned and connected Nebula access points, and what percentage of the access points become overloaded, that is, the number of online access points that exceed the maximum client device number (in Site-wide > Configure > Access points > Traffic shaping) by total number of online access points in the site. |
Wireless clients | This shows the number of WiFi clients currently connected to the managed access points. |
Switch status | This shows the number of Nebula Switches assigned and connected, and what percentage of the Switches become overloaded, that is, the number of online Nebula Switches that exceed 70% of their upstream bandwidth by total number of online Nebula Switches in the site. |
PoE power | This shows the total PoE power budget on the Switch and the current amount of power consumed by the powered devices. |
Security router / Firewall / Security Gateway status | This shows the number of Nebula Security Appliances assigned and connected, and what percentage of the Security Appliance’s processing capability is currently being used if the CPU goes over 93% usage. |
WAN utilization | This shows the data rate of inbound/outbound traffic in Kbps (kilobits per second) or Mbps (megabits per second) that has been transmitted through the WAN interface. If the Security Appliance supports multiple WAN interfaces and more than one are active, use the arrow to switch and view the throughput of each WAN interface. |
Security alert | This shows the total number of the latest alerts sent to the administrator in the last 24 hours. |
Mobile router | This shows the number of Nebula mobile routers assigned and connected. |
Security router / Firewall / Security Gateway network applications | This shows the top ten applications used by the Nebula Security Appliance in the past 24 hours. |
Security router / Firewall / Security Gateway clients by usage | This shows the top five clients of the Nebula Security Appliance with the highest percentage of bandwidth usage in the past 24 hours. |
Wireless clients | This shows the number of WiFi clients connected (clients of the access points only). |
SSIDs by usage | This shows the top five SSIDs with the highest percentage of bandwidth usage in the past 24 hours. You can click a WiFi network name to go to the Site-wide > Monitor > Access Point > Summary report screen. |
Wireless clients by usage | This shows the top five WiFi clients (clients of the access points only) with the highest percentage of bandwidth usage in the past 24 hours. You can click a client’s name to go to the Site-wide > Clients: Client list screen. |
Clients by manufacturers | This shows the top five manufacturers of WiFi client devices in the past 24 hours. You can click a manufacturer name to go to the Site-wide > Clients screen and view the client devices which are made by the manufacturer. |
Collaborative detection & response hit | This shows the total number of malicious traffic detected from wired and WiFi clients that are blocked and quarantined using Collaborative Detection & Response (CDR) in the past 7 days. |
Wireless clients by OS | This shows the top five operating systems used by WiFi client devices in the past 24 hours. You can click an operating system to go to the Site-wide > Clients screen and view the client devices which use this operating system. |
APs by usage | This shows the top five managed access points with the highest percentage of bandwidth usage in the past 24 hours. This also shows the number of WiFi clients associated with the access points. You can click an access point’s name to go to the Site-wide > Devices > Access Points: Access Points Details screen. |
APs application usage | This shows the usage statistic of the top ten applications used in the site in the past 24 hours. |
APs locations | This shows the locations of access points on the Google map. |
Threat protection by CNP services | This shows the total number of times packets coming from an IPv4 address with a bad reputation occur and the number of times connection attempts to an IPv4 address with a bad reputation occur in the past 24 hours. |
