Summary Report
Use this screen to view statistics for the Nebula Devices and networks in the selected site.
Click Site-wide > Summary report to access this screen.
Site-wide> Summary report
Label
Description
Summary report
Select to view the report for the past day, week or month. Alternatively, select Custom range... to specify a time period the report will span. You can also select the number of results you want to view in a table.
Email report
Click this button to send summary reports by email, change the logo and set email schedules.
Top devices by usage
This shows the index number of the Nebula Device.
Name
This shows the descriptive name of the Nebula Device. You can click the name to view the Nebula Device details.
Model
This shows the model number of the Nebula Device.
Usage
This shows the amount of data that has been transmitted by or through the Nebula Device.
Client
This shows the number of clients currently connected to the Nebula Device.
Location
This shows the location of the site’s gateway device on the map.
Top SSIDs by usage
This shows the ranking of the SSID.
SSID
This shows the SSID network name.
Encryption
This shows the encryption method use by the SSID network.
# Client
This shows how many WiFi clients are connecting to this SSID.
% Client
This shows what percentage of associated WiFi clients are connecting to this SSID.
Usage
This shows the total amount of data transmitted or received by clients connecting to this SSID.
% Usage
This shows the percentage of usage for the clients connecting to this SSID.
Top switches by power usage
This shows the ranking of the Nebula Switch.
Name
This shows the descriptive name of the Nebula Switch.
Model
This shows the model number of the Nebula Switch.
Power Usage
This shows the total amount of power consumed by the Nebula Switch’s connected PoE devices during the specified period of time.
Ethernet power
This graph shows power used by all PoE Switch ports in the site within the specified time, in Watts.
Avg
This shows the average power consumption for all Switch ports.
Max
This shows the maximum power consumption of the Switch ports.
Min
This shows the minimum power consumption of the Switch ports.
y-axis
The y-axis shows how much power is used by all Switches in the site, in Watts.
x-axis
The x-axis shows the time period over which power consumption is recorded.
