Group-wide
Introduction
This chapter discusses the menus that you can use to monitor and manage your groups settings.
A group is a collection of two or more organizations. Groups allow you to view and manage multiple organizations, and create VPN links between groups in the organization.
Creating a Group
Follow the steps below to create a group.
1 Ensure that you are the owner of two or more Pro Pack organizations that are not currently in a group.
2 Click the Organization list, and then select Create Group.
3 In the Create group window, enter a group name and then select two or more organizations to add to the group. You must be the group owner, and each group must have a Pro Pack license. Then click OK.
Group-Wide Menu
The Group-wide menu and the Group list appear when you create at least one group. You can select a group to manage by selecting it in the Group list.
Group-wide > Group-wide manage > Overview: Group
