) in the Configuration field.
Label | Description |
Configuration | |
Name | Enter a descriptive name for the Nebula Device. |
MAC address | This shows the MAC address of the Nebula Device. |
Serial number | This shows the serial number of the Nebula Device. |
Description | Enter a user-specified description for the Nebula Device. |
Tags | Enter a user-specified tag for the Nebula Device. |
Address | Enter a user-specified address for the Nebula Device. |
Save | Click Save to save your changes. |
Cancel | Click Cancel to exit this screen without saving. |
) in the Home networking field.
IP address assignment | |
IP address | Enter the IP address for this interface. |
Subnet mask | Enter the subnet mask of this interface in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all computers in the network. |
DHCP setting | |
DHCP Server | Select this to disable or enable the DHCP server. |
IP pool start address | Enter the IP address from which the Nebula Device begins allocating IP addresses. |
Pool size | Enter the number of IP addresses to allocate. This number must be at least one and is limited by the interface’s Subnet mask. For example, if the Subnet mask is 255.255.255.0 and IP pool start address is 10.10.10.10, the security gateway can allocate 10.10.10.10 to 10.10.10.254, or 245 IP addresses. |
Lease time | Specify how long each computer can use the information (especially the IP address) before it has to request the information again. Choices are: Infinite – select this if IP addresses never expire; days, hours, minutes – select this to enter how long IP addresses are valid. |
Close | Click Close to exit this screen without saving. |
OK | Click OK to save your changes. |
) in the Cellular IP Passthrough field. IP passthrough allows a LAN computer on the local network of the Nebula Device to have access to web services using a public IPv4 address. When IP passthrough is configured, all traffic is forwarded to the LAN computer and will not go through NAT.
IP Passthrough mode | This displays if IP passthrough is enabled on the Nebula Device. |
WiFi settings | Configure the Nebula Device’s WiFi settings using its Web Configurator. Refer to the Nebula Device’s User’s Guide for more information. |
Firewall settings | Configure the Nebula Device’s firewall settings using its Web Configurator. Refer to the Nebula Device’s User’s Guide for more information. |
Maintenance | This shows whether automatic reboot is scheduled on the Nebula Device. |
Edit | Click the Enable the schedule switch to the right to have the Nebula Device restart at a specific time on selected days of the week. By scheduling a reboot, you can have the Nebula Device refresh the network connections at a specified time, allowing automatic reconnection with WiFi clients in case of a connection failure. Select the day(s) of the week to have the automatic restart. Specify the time of the day (in 24-hour format) to have the Nebula Device automatically restart. For example, 23:00 is 11:00 PM. ![]() |
Firmware availability | The NCC automatically detects whether the firmware is up-to-date or not. Click the value in the Firmware availability field to go to the Site-wide > Configure > Firmware management screen and configure your Firmware management settings. |
Current Version | This shows the firmware version currently installed on the Nebula Device. |
Configuration status | This shows whether the configuration on the Nebula Device is up-to-date. |
WAN Usage | This shows the total amount of data consumed by the Nebula Device on the WAN (uplink/downlink) in the past 24 hours. |
LAN Usage (indoor NCCs only) | This shows the total amount of data consumed by the Nebula Device on the LAN (upllink/downlink) in the past 24 hours. |
2.4G WLAN Usage (indoor NCCs only) | This shows the total amount of data consumed by the Nebula Device on the 2.4G WiFi network (uplink/downlink) in the past 24 hours. |
5G WLAN Usage (indoor NCCs only) | This shows the total amount of data consumed by the Nebula Device on the 5G WiFi network (uplink/downlink) in the past 24 hours. |
