Admins & Teams
The Admins & teams enables you to assign an administrator or a group of administrators (a team) to multiple organizations at the same time. This is faster than configuring administrators for each organization at Organization-wide > Administrators, especially if you have a large number of organizations.
Administrator Privilege Priority
You can configure organization administrator privileges on the following screens:
• MSP cross-org > MSP cross-org manage > Admins & teams > Admins
• MSP cross-org > MSP cross-org manage > Admins & teams > Teams
• Group-wide > Group-wide manage > Administrators
• Organization-wide > Administrators
If an NCC account has different administrator privileges configured on different screens, then the highest privilege level takes priority.
Example, account User1 has four different privilege levels configured for organization Org1 on the four screens above: None, Read-Only, Full, Full (Delegate). User1’s final privilege level for Org1 is Full (Delegate).
Admins Screen
The admins screen allows you to assign an administrator account to multiple organizations. To access this screen, click MSP cross-org > MSP cross-org manage > Admins & teams > Admins.
Label
Description
Activation
Click this button to Activate/Deactivate the selected accounts. Then, click Apply.
Delete
Click this button to remove group administrator privileges for the selected accounts.
Search
Specify your desired filter criteria to filter the list of administrator accounts.
N administrators
This shows the number of administrator accounts (N) in the list.
Import
Click this button to create administrator accounts in bulk by importing a complete list of all new administrators in an Excel file. Click template to view and use the file format.
Add
Click this button to create a new group administrator account.
Email address
This shows the email address of the administrator account.
Name
This shows the name of the administrator account.
Description
This shows the user-specified description for the administrator account.
Organization
This shows the name of the organization in which the privileges apply.
Organization type
This shows the license tier of the organization.
Org. privilege
This shows the privileges the administrator has within the specified organization.
Full: the administrator can edit settings, create or delete other administrator accounts, create or delete a site, and add or renew licenses for Nebula Devices in the organization.
Read-only: the administrator account has no write access to the organization, but can be a site administrator.
Delegate owner’s authority: The administrator account has delegated owner privileges. This type of account can perform all of the same actions as the organization owner, except for the following:
• Delete organization
• Transfer organization ownership
• Assign delegate owner privileges to an administrator account
Site privilege
This shows the privileges the administrator has within the specified site.
Full: the administrator can edit settings, create or delete other administrator accounts, create or delete a site, and add or renew licenses for Nebula Devices in the site.
Read-only: the administrator account has no write access to the site, but can be a site administrator.
Monitor-only: the administrator can view the site’s monitor pages for Nebula Access Points, Ethernet Switches, and Security Appliances only. The configuration pages are hidden from view.
Installer: the administrator can register Nebula Devices at this site.
Guest Ambassador: the administrator can create, remove or manage guest accounts using the Cloud authentication screen.
Expires
This shows how long the account is valid.
Never expire – this account never expires.
Expire on – this specifies the date the account is valid.
Account status
This shows whether the administrator account has been validated (OK). It shows Deactivated if an administrator account has been created but cannot be used. This may happen since you can only have up to 5 active administrator account in NCC base tier.
Last access time (UTC)
This shows the last date and time traffic was sent from the administrator account.
Create date (UTC)
This shows the date and time the administrator account was created.
Status change date (UTC)
This shows the last date and time the administrator account status was changed.
Creator
This shows the name of the MSP user account that added the privilege settings.
Click this icon to display a greater or lesser number of configuration fields.
Create/Update Administrator
In the MSP cross-org > MSP cross-org manage > Admins & teams > Admins screen, click the Add button to add a new administrator account, or double-click an existing account entry to modify the account settings.
*NCC does not count the administrators created in Admin & teams to the Base tier and Nebula Plus Pack number of administrator account limit.
An NCC account with an MSP license can add administrators (with/without an MSP license) to the Base tier and Nebula Plus Pack organizations without limit.
MSP cross-org > MSP cross-org manage > Admins & teams > Admins: Create/Update administrator
Label
Description
Name
Enter a descriptive name for the administrator account. Enter up to 100 characters in this field including special characters inside the square quotes [~!@#$%^&*()_+{}|:”<>?–=[]\;’,./].
Email address
Enter the email address of the administrator account, which is used to log into the NCC.
This field is read-only if you are editing an existing account.
Description
Enter a description for this administrator. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long.
Validity
Specify how long the account is valid. Choices are:
Never expire – select this if the account never expire.
Expire on – select this to specify the date the account can no longer access the organization.
Select Delete this admin when expired to remove this account from the administrator list when the Expire on date has been reached. Otherwise, this account will remain on the administrator list with an inactivated status.
Assign privilege
Organization only
Select this to assign the account privileges to all the sites in the selected organizations. Only organizations belonging to an MSP account with full privileges can be selected.
Organization
Select one or more organizations to assign the account privileges to.
*If no organization is selected, then the administrator cannot access any organization until an organization is assigned full privileges.
Privilege
Select the privileges the administrator has within the selected organizations.
Activate
Select Yes to enable the account or No to temporarily disable the account.
Click the remove icon to delete the current set of admin privileges.
Add
Add administrator privileges for an organization.
Sites of an organization
Select this to assign the account privileges to the site(s) in the selected organization. Only organizations belonging to an MSP account with full privileges can be selected.
Organization
Select an organization to assign the account privileges to.
Sites
Select one or more sites to assign the account privileges to.
Site privilege
Select the privileges the administrator has within the selected sites.
Activate
Add
Add administrator privileges for the site(s) in an organization.
Close
Click this button to exit this screen without saving.
Create admin/Update admin
Click this button to save your changes and close the screen.
Teams Screen
The team screen allows you to assign administrator privileges to a group of NCC accounts (a team). To access this screen, click MSP cross-org > MSP cross-org manage > Admins & teams > Teams.
Label
Description
Delete
Click this button to remove the selected teams.
Search
Specify your desired filter criteria to filter the list of teams.
N teams
This shows the number of teams (N) in the list.
Add
Click this button to create a new administrator team.
Select an entry’s checkbox to select a specific team. Otherwise, select the checkbox in the table heading row to select all teams.
Name
This shows the name of the team.
Description
This shows a description of the team.
Org. privilege
This shows the privileges the team has within the specified organizations.
Organization
This shows the names of the organizations in which the privileges apply.
Administrator
This shows a list of the administrators in the team.
Create date (UTC)
This shows the date and time the team was created.
This shows the last date and time the team status was changed.
Creator
Create/Update Team
In the MSP cross-org > MSP cross-org manage > Admins & teams > Teams screen, click the Add button to add a new administrator team, or double-click an existing team entry to modify its settings.
MSP cross-org > MSP cross-org manage > Admins & teams > Teams: Create/Update team
Label
Description
Name
Enter a descriptive name for the team. Enter up to 15 characters in this field including special characters inside the square quotes [~!@#$%^&*()_+{}|:”<>?–=[]\;’,./].
Description
Enter a description of the team, for example their role or membership. Enter up to 64 characters for this field including special characters inside the square quotes [~!@#$%^&*()_+{}|:”<>?–=[]\;’,./].
Assign privilege
Select the privileges the team members have within the selected organizations.
Full: Each member of the team can edit settings, create or delete other administrator accounts, create or delete a site, and add or renew licenses for Nebula Devices in the organization.
Read-only: Each member of the team has no write access to the organization, but can be a site administrator.
Organization
Select one or more organizations to assign the team privileges to. An organization can belong to multiple teams.
Members
Name
Enter a descriptive name for the members. Enter up to 15 characters for this field including special characters inside the square quotes [~!@#$%^&*()_+{}|:”<>?–=[]\;’,./].
Email address
Enter the email address of the members who can log into the NCC.
Add
Add another NCC account to this team.
Close
Create/Update
