Backup and Restore
Use these screens to back up your current Nebula Device’s configurations to NCC, or restore a previously saved configuration. Click MSP > MSP cross-org manage > Backup & restore to access these screens.
At the time of writing, you can do the following:
– In Cloud mode, back up a Security Firewall’s running configuration to NCC and restore a running configuration from NCC to a Security Firewall
– In Cloud Monitoring mode, back up a Security Firewall’s local Web Configurator settings to NCC and restore a local Web Configurator settings from NCC to a Security Firewall
– In Cloud mode, back up a Security Router’s running configuration to NCC and restore a running configuration from NCC to a Security Router.
You cannot use the local Web Configurator settings in Cloud Monitoring mode to restore the running configuration of the Nebula Device in Cloud mode. Likewise, you cannot use the running configuration in Cloud mode to restore the local Web Configurator settings of the Nebula Device in Cloud Monitoring mode.
A maximum of 10 backups are allowed per site. This includes the backups done in the
MSP >
Backup & restore and
Site-wide >
Devices >
Firewall:
Live tools:
Backup & Restore screens. NCC will automatically remove the oldest backup after exceeding 10 backups.
A backup done in the
MSP >
Backup & restore screen is also added to the
Site-wide >
Devices >
Firewall:
Live tools:
Backup & Restore screen.
A manual or scheduled back up done in the
Site-wide >
Devices >
Firewall:
Live tools:
Backup & Restore screen is also added to the
MSP >
Backup & restore screen.
The backups will be removed from NCC when the site it belongs to is deleted.
Backup and Restore Overview Screen
Use this screen to perform a backup or view a list of previous backups and the details. Click MSP > MSP cross-org manage > Backup & restore > Overview to access this screen.
Label | Description |
Backup | Click this button to create a new backup of the current configuration of the Nebula Device to the NCC. |
Search | Select the filter criteria to filter the list of Nebula Devices. |
N devices | This shows how many Nebula Devices (N) match the filter criteria and how many Nebula Devices of the selected type are created in total. |
| Select an entry’s checkbox to select a specific entry. Otherwise, select the checkbox in the table heading row to select all entries. |
Organization | This shows the descriptive name of organization. |
Site | This shows the descriptive name of site. |
Device type | This shows the type of Nebula Device. |
Model | This shows the model name of the Nebula Device. |
Last backup | This shows the date and time the backup was saved on the NCC server. |
Backups | Click Detail to go to the Backups screen. See the next section for details. |
Backup and Restore Backups Screen
Use this screen to restore a backup to your Nebula Device. Click MSP > MSP cross-org manage > Backup & restore > Backups to access this screen.
Search | Select the filter criteria to filter the list of backups. |
N files | This shows how many backups (N) match the filter criteria and how many Nebula Devices of the selected type are created in total. |
Backups | This shows the automatically generated filename of the backup. The format is “Organization name_Site name_Nebula Device model_backup date and time”.  NCC hides the backup when all compatible Nebula Device(s) are removed from the site.  A hidden Security Appliance backup is displayed again when any model of a Security Appliance is added to the site. |
Organization | This shows the descriptive name of the organization. |
Site | This shows the descriptive name of the site. |
Description | This shows the user-specified description entered during the backup. |
Backup time | This shows the date and time of the site, and when the backup was done. |
Actions | Click the Edit icon to change the description. You can use alphanumeric and ()+/:=?!*#@$_%- characters, up to 512 characters. Click the Restore icon to restore a previously saved local GUI or Cloud configurations from NCC to the Nebula Device.  To restore Cloud configurations, the Nebula Device can be online or offline. To restore local GUI settings, the Nebula Device must be online. Click the Download icon to download the configuration file to your computer or laptop. Click the Delete icon to remove a previously saved local GUI or Cloud settings from NCC. |
