Label | Description |
Applications | In Application view, select to view all applications of Nebula Security Appliances / Nebula Access Points, or only applications with bandwidth or block policies applied to Nebula Security Appliances. In Category view, select to view all applications of Nebula Security Appliances / Nebula Access Points only. Select to view the report for the past day or week. Alternatively, select Custom range... to specify a time period the report will span. You can also select the number of results you want to view in a table. ![]() |
![]() | Click this button to reload the data-related frames on this page. |
Category View / Application View | Click this button to view statistics by application or category. |
y-axis | The y-axis shows the total amount of data used by applications or categories in the site. |
x-axis | The x-axis shows the time period over which the data usage occurred. |
Keyword | Enter a keyword to filter the list of log entries. |
N applications/categories | This shows the number of applications/categories (N) in the list. |
Application/Category-View Fields | |
Status | This shows whether the application or category is blocked or allowed within the current site. |
Application | This shows the application name. |
Category | This shows the name of the category to which the application belongs. |
Bandwidth limit | This shows the bandwidth restriction policy for the application. |
Usage | This shows the amount of data consumed by the application, or all applications in the category. |
% Usage | This shows the percentage of usage for the application or category. |
Limit | Click this to limit the bandwidth for the application on the site’s gateway. You can apply the restrictions per gateway interface, or for all interfaces. |
