Map/Photo
Click the Map tab. This shows the location of the Nebula Device on Google map. To upload a photo of the Nebula Device, select the Photo tab.
Site-wide > Devices > Mobile router > Map
Site-wide > Devices > Mobile router > Map/Photo
Label
Description
Map
This shows the location of the Nebula Device on Google Maps (Map view or Satellite imagery view) or on a floor plan. Click Floor plan to display a list of existing floor plans. Each floor plan has a drawing that shows the rooms scaled and viewed from above. Drag-and-drop your Nebula Device directly on the Google map or click Position device to update the Nebula Device’s address (physical location).
• Select GEO IP to use the public IP address of the Nebula Device.
• Select Get my location from web browser to use the public IP address of the computer accessing the NCC portal.
• Select Use the following address or coordinates to enter the complete address or coordinates of the Nebula Device.
*Nebula Devices that are offline cannot use GEO IP.
This shows the photo of the Nebula Device. Click Add to upload up to five photos of your Nebula Device. Click the remove icon () to delete a photo.
