Use Tags to Assign SSIDs for Nebula Devices (for Nebula Access Points only)
When you have 2 Nebula Devices in different locations (for example, one in the lobby and one in the office), and you want Nebula Device A to only broadcast the SSID “SSID_lobby” and Nebula Device B “SSID_office” then do the following:
1 Go to Site-wide > Devices > Access points. Select the “Lobby_AP” and click Tag. Enter “lobby” and click + Add new.
2 Click Add to assign the “lobby” tag to the “Lobby_AP”.
3 Select the “Office_AP” and click Tag. Enter “office” and click + Add new.
4 Click Add to assign the “office” tag to the “Office_AP”.
The new Tags appear on the lobby and office APs in Site-wide > Devices > Access points.
5 Go to Site-wide > Configure > SSID settings. Select the “lobby” tag for the previously configured “SSID_lobby”. Select the “office” tag for the previously configured “SSID_office”.
The Nebula Devices will broadcast SSIDs according to the assigned tags. Go to Site-wide > Clients to check the WiFi clients connection status.
