Change the WiFi Band Mode
If your WiFi network is slow, change the WiFi band mode. Choose 6G if the connected WiFi clients support it. Choose 5G for WiFi clients within range that require higher speeds such as video streaming.
To change the WiFi network band mode:
1 Go to the Site-wide > Configure > Security router / Access points > SSID settings tab and click Edit.
2 In the Site-wide > Configure > Access points > SSID advanced settings: Advanced settings: Band mode; select to have the SSID use a different band (2.4 GHZ band, 5 GHz band, or 6 GHz band).
3 Click Back to proceed.
