Monitor Client Bandwidth Usage (for Security Firewalls in Nebula only)
To view network statistics for the Nebula Device of the selected site, such as top client bandwidth usage, do the following.
1 Go to Site-wide > Monitor > Firewall > Summary report to select to view the result for the past day, week or month. Alternatively, choose Custom range... to specify a time period the report will span. You can also select the number of results you want to view in a table. Then, click Update.
2 Check the Top clients by usage widget.
