Configure Schedule to Allow WiFi Access Only at Certain Times
This example shows you how to allow WiFi Internet access only at certain times.
To configure a schedule to control when a WiFi network (SSID) is enabled or disabled, do the following:
1 Go to Site-wide > Configure > Access points > SSID advanced settings. Click the Enabled switch in SSID schedule to the right to configure a schedule. The New Schedule window appears. Enter a descriptive Name for the schedule of up to 127 characters (0 – 9 a – z). The casing does not matter. Then, click Create.
2 The schedule Name appears on Schedule. To change it, click the edit icon () . Select Custom schedule in Schedule template to manually configure the Day and time at which the WiFi network (SSID) is enabled. Click the Availability switch to the right to enable the WiFi network (SSID) at the specified time on this day. Specify the hour and minute when the schedule begins and ends each day. Then click Save.
