Label | Description |
Reserved IP Address Pool | Specify the IP addresses that Nebula Devices use to create the VPN tunnels between the gateway devices in the org-to-org VPN network. You can select a set or custom range. This IP address range must not overlap with any IP address ranges already in use within any sites in the org-to-org VPN. |
AutoVPN | |
Hub to Hub VPN | Turn the switch to On to enable create VPN tunnels between the hubs in the list. This is required to enable Org-to-Org VPN. When this setting is disabled, Org-to-Org VPN will not work and can only be configured. |
Organization | This column lists down the organization to which the hub site belongs. |
Hub | This column lists down the names of the hub sites included in the Org-to-Org VPN. |
+Hub | Click this to set up which hub site you want to add to the Org-to-Org VPN. |
Service | |
Organization | This displays the organization to which the network service belongs. |
FQDN | This displays the Fully-Qualified Domain Name (FQDN) associated with the network service which Security Gateway devices and Nebula Devices behind them are given access. |
IP Address | This displays the IP address of the network service which Security Gateway devices and Nebula Devices behind them are given access. |
+Org-to-Org Service | Click this to add a service that can be accessed within the org-to-org VPN. |
Save | Click this button to save your changes and close the screen. |
Cancel | Click Cancel to exit this screen without saving. |
label | description |
All Organization Hubs | This box lists all hub sites in the group that are outside the org-to-org network. It shows the name of the hub followed by the Organization it belongs to in parentheses. |
Within Org-to-Org | This box lists all hub sites inside the org-to-org network. It shows the name of the hub followed by the Organization it belongs to in parentheses. |
Save | Click Save to add the hubs to the org-to-org network. |
Organization | Select the organization to which the service you want to add is linked to. |
FQDN | Enter the Fully-Qualified Domain Name (FQDN) associated with the service. An FQDN starts with a host name and continues all the way up to the top-level domain name. For example, www.zyxel.com.tw is a fully qualified domain name, where “www” is the host, “zyxel” is the third-level domain, “com” is the second-level domain, and “tw” is the top level domain. Underscores are not allowed. Use "*." as a prefix in the FQDN for a wildcard domain name (for example, *.example.com). |
IP Address | Enter the IP address of the service you want to add to the org-to-org VPN. |
Save | Click Save to allow access to the service through the org-to-org VPN. |
