Label | Description |
Threat report | Select to view the report for the past day, week or month. Alternatively, select Custom range... to specify a time the report will span. You can also select the number of results you want to view in a table. Then, click Update. |
Email report | Click this button to send threat reports by email, change the logo and set email schedules. |
Location | This shows the location on the map where the blocked threats occurred by category. |
Threat Management by category | |
Category | This shows the name of the category to which the threat belongs. Click the Category to display the individual category statistics table. The category statistics table includes the following fields: • Domain/Website/IP • Hits • %Hits |
Hits | This shows the amount of hits on a specific threat category. |
% Hits | This shows the percentage of the hit counts for the threat encountered by a specific category. |
Threat Management by client | |
Description | This shows the name of the client device who encountered a threat. Click the name to display the individual client statistics table. The client statistics table includes the following fields: • Domain/Website/IP • Category • Hits • %Hits |
IPv4 address | This shows the IPv4 address of the client device who encountered a threat. |
MAC address | This shows the MAC address of the client device who encountered a threat. |
Hits | This shows the number of threat hits of the client device. |
% Hits | This shows the percentage of the hit counts encountered by a specific client device. |
Click this button to reload the data on this page. | |
Connection Status | |
Configuration | This shows the number and address of the local networks behind the Nebula Device, on which the computers are allowed to use the VPN tunnel. |
Site Connectivity | |
Location | This shows the name of the site to which the Nebula peer gateway is assigned. Click the name to view the VPN usage and connectivity status screen. |
Subnet | This shows the address of the local networks behind the Nebula peer gateway. |
Status | This shows whether the VPN tunnel is connected or disconnected. |
Last heartbeat | This shows the last date and time a heartbeat packet is sent to determine if the VPN tunnel is up or down. |
Non-Nebula VPN peers connectivity | |
Location | This shows the name of the site to which the Non-Nebula peer gateway (Zyxel or non-Zyxel IPSec VPN gateway and Cloud VPN (Azure VPN or AWS VPN)) is assigned. Click the name to go to the Site-wide > Configure > Security router > Site-to-Site VPN screen, where you can modify the VPN settings. |
Subnet | This shows the address of the local networks behind the Non-Nebula peer gateway. |
Inbound | This shows the amount of traffic that has gone through the VPN tunnel from the Non-Nebula peer gateway to the Nebula Device since the VPN tunnel was established. |
Outbound | This shows the amount of traffic that has gone through the VPN tunnel from the Nebula Device to the Non-Nebula peer gateway since the VPN tunnel was established. |
Tunnel up time | This shows how many seconds the VPN tunnel has been active. |
Last heartbeat | This shows the last date and time a heartbeat packet was sent to determine if the VPN tunnel is up or down. |
