Accessory
Overview
This chapter discusses the menus that you can use to monitor the Nebula-managed Accessories in your network and configure settings even before an Accesssory is deployed and added to the site.
An Accessory can be managed by Nebula. It is referred to as a Nebula Device in this chapter.
Configuration
From the navigation panel, click Site-wide > Devices > Accessory and the following screen appears.
Site-wide > Devices > Accessories
Label
Description
Accessories
Select to view device information and connection status in the past 2 hours, day, week, month.
Click this button to reload the data-related frames on this page.
Action
Perform an action on the selected Nebula Devices.
Reboot
Select this to restart the Nebula Device.
Tag
Select one or multiple Nebula Devices and click this button to create a new tag for the Nebula Devices or delete an existing tag.
Move
Select one or multiple Nebula Devices and click this button to move the Nebula Devices to another site or remove the Nebula Devices from the current site.
Search
Specify your desired filter criteria to filter the list of Nebula Devices.
Accessories
This shows the number of Nebula Devices connected to the site network.
Export
Click this button to save the accessories list as a CSV or XML file to your computer.
Click this to select all the rows in this table.
Status
This shows the status of the Nebula Device.
• Green: The Nebula Device is online and has no alerts.
• Amber: The Nebula Device has alerts. Hover the mouse over the icon to find the problem.
• Red: The Nebula Device is offline.
• Gray: The Nebula Device has been offline for 7 days or more.
Click the Nebula Device on this page to go to the Nebula Device’s details screen for more information.
Name
This shows the descriptive name of the Nebula Device.
Tag
This shows the user-specified tag for the Nebula Device.
MAC address
This shows the MAC address of the Nebula Device.
LAN IP
This shows the local (LAN) IP address of the Nebula Device.
Public IP
This shows the global (WAN) IP address of the Nebula Device.
Model
This shows the model number of the Nebula Device.
Configuration status
This shows whether the configuration on the Nebula Device is up-to-date.
Product information
This shows the production information of the Nebula Device.
Connectivity
This shows the accessory connection status.
The red time slot indicates the connection to the NCC is down, and the green time slot indicates the connection is up. Move the cursor over a time slot to see the actual date and time when an Nebula Device is connected or disconnected.
Serial number
This shows the serial number of the Nebula Device.
Firmware status
This shows whether the firmware installed on the Nebula Device is up-to-date.
Firmware type
This shows Stable when the installed firmware may not have the latest features but has passed Zyxel internal and external testing.
This shows Latest when the installed firmware is the most recent release with the latest features, improvements, and bug fixes.
This shows General Availability when the installed firmware is a release before Latest, but is still undergoing Zyxel external testing.
This shows Dedicated when the installed firmware is locked and Zyxel support is monitoring. Contact Zyxel customer support if you want to unlock the firmware in order to upgrade to a later one.
This shows Beta when the installed firmware is a release version for testing the latest features and is still undergoing Zyxel internal and external testing.
This shows N/A when the Nebula Device is offline and its firmware status is not available.
Firmware availability
This shows whether the firmware on the Nebula Device is Up to date, there is firmware update available for the Nebula Device (Upgrade available), or a specific version of firmware has been installed by Zyxel customer support (Locked).
Current version
This shows the firmware version currently installed on the Nebula Device.
IP type
This shows whether the IP address was assigned automatically (DHCP), or manually (Static IP).
Click this icon to display a greater or lesser number of configuration fields. For faster loading of data, select only the configuration fields listed that do NOT take a long time to fetch data.
Accessories Details
Click a Nebula Device entry in the Site-wide > Devices > Accessories screen to display individual Nebula Device statistics.
Site-wide > Devices > Accessories: Details
Label
Description
Status
LAN IP
This shows the local (LAN) IP address of the Nebula Device. It also shows the IP addresses of the gateway and DNS server.
Click the edit icon to open a screen where you can change the IP addresses, VLAN ID number and tagging setting.
*To prevent an IP address conflict, NCC will prevent input of an IP address already used by another Nebula Device in the same site.
Public IP
Topology
Click Show to go to the Site-wide > Topology screen. See Topology.
Neighbor info
This shows the LLDP information received on the up-link port.
This shows whether the firmware on the Nebula Device is up-to-date or there is firmware update available for the Nebula Device.
Current version
Configuration
Click the edit configuration icon to change the Nebula Device name and tags. You can also move the Nebula Device to another site or remove.
By default, the Nebula Device’s hostname is the MAC address. Enter a Name to identify the Nebula Device. You can use up to 64 alphanumeric characters including period (.) and hyphen (-). Spaces are not allowed.
*The period (.) and hyphen (-) cannot be the first character, last character, or appear consecutively on the Name. For example, -wax650, wax650-, wax650..wax650, wax650.-wax650.
Name
MAC address
Serial number
Change site
Select the new site from the drop-down menu or click Remove to remove the Nebula Device from the site.
Tags
Live tools
Ping
Enter the domain name or IP address of a computer that you want to perform ping from the Nebula Device in order to test a connection and click Ping.
This can be used to determine if the Nebula Device and the computer are able to communicate with each other.
Reboot device
Click the Reboot button to restart the Nebula Device.
*All connected clients will be temporarily disconnected during reboot.
Remote configurator
This allows you to establish a remote connection to this Nebula Device by specifying the IP address and port number. Then click Establish.
This feature is available to the organization owner, organization administrators with full privileges, and site administrators with full privileges.
Connectivity
Move the cursor over the chart to see the transmission rate at a specific time.
Zoom
Select to view the statistics in the past 2 hours, day, week, or month.
Pan
Click to move backward or forward by one day or week.
