Label | Description |
![]() | Click this button to reload the data-related frames on this page. |
Connection Status | |
Configuration | This shows the number and address of the local networks behind the Nebula Device, on which the computers are allowed to use the VPN tunnel. |
NAT Type | This shows the public IP address or the domain name that is configured and mapped to the Nebula Device on the NAT router. |
Site Connectivity | |
Location | This shows the name of the site to which the peer gateway is assigned. Click the name to go to the Site-wide > Configure > Security gateway > Site-to-Site VPN screen, where you can modify the VPN settings. |
Subnet(s) | This shows the address of the local networks behind the Nebula Device. |
Status | This shows whether the VPN tunnel is connected or disconnected. |
Inbound (Bytes) | This shows the amount of traffic that has gone through the VPN tunnel from the remote IPSec router to the Nebula Device since the VPN tunnel was established. |
Outbound (Bytes) | This shows the amount of traffic that has gone through the VPN tunnel from the Nebula Device to the remote IPSec router since the VPN tunnel was established. |
Tunnel up time | This shows how many seconds the VPN tunnel has been active. |
Last heartbeat | This shows the last date and time a heartbeat packet is sent to determine if the VPN tunnel is up or down. |
Client to site VPN login account | |
User Name | This shows the remote user’s login account name. |
Hostname | This shows the name of the computer that has this L2TP VPN connection with the Nebula Device. |
Assigned IP | This shows the IP address that the Nebula Device assigned for the remote user’s computer to use within the L2TP VPN tunnel. |
Public IP | This shows the public IP address that the remote user is using to connect to the Internet. |
Security Appliance – NSS Analysis | Select to view the report for the past day, week or month. Alternatively, select Custom range... to specify a time period the report will span. You can also select the number of results you want to view in a table. ![]() |
Select the type of service for which you want to view the statistics report. | |
Email report | Click this button to send summary reports by email, change the logo and set email schedules. |
Application The following fields displays when you select to view the application statistics. Click an application name to view information about the clients who use that application. Click Top Application under the chart to switch back to the previous screen. | |
y-axis | The y-axis shows the amount of the application’s traffic which has been transmitted or received. |
x-axis | The x-axis shows the time period over which the traffic flow occurred. |
Application | This shows the name of the application. Click an application name to view the IPv4 addresses of the clients who used the application. |
Description | This shows the name of the client who used the application. This field is available when you click the application name. Click the name to display the individual client statistics. See Event Log. |
IPv4 Address | This shows the IPv4 address of the client who used the application. This field is available when you click the application name. |
MAC Address | This shows the MAC address of the client who used the application. This field is available when you click the application name. |
Category | This shows the name of the category to which the application belongs. |
Usage | This shows the total amount of data consumed by the application used by all or a specific IPv4 address. |
% Usage | This shows the percentage of usage for the application used by all or a specific IPv4 address. |
Content Filtering The following fields display when you select to view the content filter statistics. Click a website URL to view information about the clients who tried to access that web page. Click Content Filtering under the chart to switch back to the previous screen. | |
y-axis | The y-axis shows the number of hits on web pages that the Nebula Device’s content filter service has blocked. |
x-axis | The x-axis shows the time period over which the web page is checked. |
Website | This shows the URL of the web page to which the Nebula Device blocked access. Click a website URL to view the IPv4 addresses of the clients who tried to access the web page. |
Description | This shows the name of the client who tried to access the web page. This field is available when you click the website URL. Click the name to display the individual client statistics. See Event Log. |
IPv4 Address | This shows the IPv4 address of the client who tried to access the web page. This field is available when you click the website URL. |
MAC Address | This shows the MAC address of the client who tried to access the web page. This field is available when you click the website URL. |
Category | This shows the name of the category to which the web page belongs. |
Hits | This shows the number of hits on the web page visited by all or a specific IPv4 address. |
% Hits | This shows the percentage of the hit counts for the web page visited by all or a specific IPv4 address. |
Anti-Virus The following fields are displayed when you select Anti-Virus. Click a virus name to view information about the clients who sent the virus. Click the number in the center of the donut chart or Anti-Virus under the chart to switch back to the previous screen. | |
y-axis | The y-axis shows the total number of viruses that the gateway has detected. |
x-axis | The x-axis shows the time period over which the virus is detected. |
Virus Name | This shows the name of the virus that the Nebula Device has detected and blocked. Click a virus name to view the IPv4 addresses of the clients who sent the virus. |
Description | This shows the name of the client who sent the virus. This field is available when you click the virus name. Click the name to display the individual client statistics. See Event Log. |
IPv4 Address | This shows the IPv4 address of the virus sender. This field is available when you click the virus name. |
MAC Address | This shows the MAC address of the virus sender. This field is available when you click the virus name. |
Hits | This shows how many times the gateway has detected the virus sent by all or a specific IPv4 address. |
% Hits | This shows the percentage of the hit counts for the virus sent by all or a specific IPv4 address. |
Intrusion Detection / Prevention The following fields are displayed when you select Intrusion Detection / Prevention. The donut chart shows the number of potential network attacks detected by the Intrusion Detection and Prevention (IDP) service, if any. The number in the center of the donut chart indicates the number of network attacks blocked by the IDP service. | |
Signature Name | The name of the IDP signature that triggered the hit. The signature name identifies the type of intrusion pattern |
Hits | This shows the total number of network attacks blocked by the IDP service. |
% Hits | This shows the number of network attacks blocked as a percentage of the total number of network requests scanned by the IDP service. |
Security gateway – Summary report | Select to view the report for the past day, week or month. Alternatively, select Custom range... to specify a time period the report will span. You can also select the number of results you want to view in a table. ![]() |
WAN1/WAN2 usage | |
y-axis | The y-axis shows the transmission speed of data sent or received through the WAN connection in kilobits per second (Kbps). |
VPN usage | |
y-axis | The y-axis shows the transmission speed of data sent or received through the VPN tunnel in kilobits per second (Kbps). |
Security gateway by usage | |
This shows the index number of the Nebula Device. | |
Name | This shows the descriptive name of the Nebula Device. |
Model | This shows the model number of the Nebula Device. |
Usage | This shows the amount of data that has been transmitted through the Nebula Device’s WAN port. |
Client | This shows the number of clients currently connected to the Nebula Device. |
Location This shows the location of the Nebula Devices on the map. | |
Top applications by usage | |
This shows the index number of the application. | |
Application | This shows the application name. |
Usage | This shows the amount of data consumed by the application. |
% Usage | This shows the percentage of usage for the application. |
Top ports by usage | This shows the top ten applications/services and the ports that identify a service. |
Name | This shows the service name and the associated port numbers. |
Usage | This shows the amount of data consumed by the service. |
% Usage | This shows the percentage of usage for the service. |
Clients per day | |
y-axis | The y-axis represents the number of clients. |
x-axis | The x-axis represents the date. |
Top operating systems by usage | |
This shows the index number of the operating system. | |
OS | This shows the operating system of the client device. |
# Client | This shows how many client devices use this operating system. |
% Client | This shows the percentage of top client devices which use this operating system. |
# Usage | This shows the amount of data consumed by the client device on which this operating system is running. |
% Usage | This shows the percentage of usage for top client devices which use this operating system. |
Top clients by usage | |
This shows the index number of the client. | |
Description | This shows the descriptive name or MAC address of the client. |
Usage | This shows the total amount of data transmitted and received by the client. |
% Usage | This shows the percentage of usage for the client. |
Top client device manufacturers by usage | |
This shows the index number of the client device. | |
Manufacturer | This shows the manufacturer name of the client device. |
Client | This shows how many client devices are made by the manufacturer. |
% Client | This shows the percentage of top client devices which are made by the manufacturer. |
Usage | This shows the total amount of data transmitted and received by the client device. |
% Usage | This shows the percentage of usage for the client device. |
