Getting Started
You can perform network management with the NCC using a web browser. Use a browser that supports HTML5, such as Microsoft Edge, Mozilla Firefox, or Google Chrome. The recommended browser is Google Chrome.
View the browser in full screen mode to display the NCC portal properly.
Connect Nebula Managed Devices
Connect your Nebula managed devices (such as the NAP102 or the NSW100-28P) to your local network. Your local network must have Internet access. See the corresponding Quick Start Guides for hardware connections.
Access the NCC Portal
Go to the NCC portal website.
1 Enter http://nebula.zyxel.com in a supported web browser. Click Get Started.
2 To log in using your Google Account, click Continue with Google and then click Sign In.
Or, to log in using your Apple Account, click Continue with Apple and then click Sign In.
Or, enter the Zyxel Account Email and Password, and then click Sign In.
*To log into the NCC with your Zyxel Account., click Create an account with your existing email address if you do not have a Zyxel Account.
*The Zyxel Account does not allow account creation using disposable email addresses.
*When you log in using a social account (Google or Apple) but the email address was registered with a Zyxel Account, the system will prompt you to perform a login account transfer. You must agree to this before proceeding with the social account login. After the login account transfer, you can only log in using the social account method, not the Zyxel Account method.
*Two-factor authentication, changing password, and forget password for social account logins are managed on your social account settings.
*Organization-wide two-factor authentication is not allowed when you log in using a social account (Google or Apple).
*Click Try demo to enter the Demo Site. The Demo Site allows you to explore the NCC Portal.
3 Click Create organization to create a new organization. If this is the first time you have logged into NCC, proceed to step 9.
If you have more than one organization, click a row to select the organization you want to manage.
4 The NCC supports two-factor authentication (2FA) to add a second layer of security to your account. Click Manage account to enable Two-factor authentication on the following page. Otherwise, you can skip 2FA and go to step 9 directly.
5 Click Two-factor authentication and then click the switch to enable Two-factor authentication.
6 The following screen appear. Activate the two-step verification service using the Google Authenticator app or your email address. If you select Google Authenticator, install the app on your smartphone and scan the QR code on the NCC web screen to get a 6-digit one-time code. Then enter the code and click Verify to authenticate your identity.
Alternatively, click Email authentication to use your email to authenticate.
If you select Email authentication, an email is sent to your Zyxel Account’s email address. Click the Enable 2FA link in the email.
7 Click OK to confirm email authentication the next time you need to log in again.
8 To re-log in Nebula after the Two-factor authentication is enabled. Go to Applications > Nebula and then click the Sign In link on the Zyxel Account Login Verification email to log in your Nebula account.
9 If this is the first time you have logged into NCC, the setup wizard welcome screen displays. You need to create your organization and sites, register Nebula Devices and associate them with a site. See Setup Wizard for how to use the wizard.
Access the Nebula SD-WAN (Orchestrator) Portal
Go to the Nebula SD-WAN (Orchestrator) web portal to configure ZyWALL VPN devices. This is only available if you have purchased the SD-WAN license for Orchestrator Management.
1 Enter https://go.sd-wan.nebula.zyxel.com in a supported web browser. Click Sign in.
Or, enter the Zyxel Account Email and Password, and then click Sign in.
*Click Try demo to enter the Demo Site. The Demo Site allows you to explore the Nebula SD-WAN (Orchestrator) portal.
3 Read the GDPR Statement and click Agree to enter the Nebula SD-WAN (Orchestrator) portal.
You can click Control Center to go to the NCC platform.
