Label | Description |
![]() | Click this button to reload the data on this page. |
Connection Status | |
Configuration | This shows the number and address of the local networks behind the Nebula Device, on which the computers are allowed to use the VPN tunnel. |
Site Connectivity | |
Location | This shows the name of the site to which the Nebula peer gateway is assigned. Click the name to view the VPN usage and connectivity status screen. |
Subnet | This shows the address of the local networks behind the Nebula peer gateway. |
Status | This shows whether the VPN tunnel is connected or disconnected. |
Last heartbeat | This shows the last date and time a heartbeat packet is sent to determine if the VPN tunnel is up or down. |
Non-Nebula VPN peers connectivity | |
Location | This shows the name of the site to which the Non-Nebula peer gateway (Zyxel or non-Zyxel IPSec VPN gateway and Cloud VPN (Azure VPN or AWS VPN)) is assigned. Click the name to go to the Site-wide > Configure > Security router > Site-to-Site VPN screen, where you can modify the VPN settings. |
Subnet | This shows the address of the local networks behind the Non-Nebula peer gateway. |
Inbound | This shows the amount of traffic that has gone through the VPN tunnel from the Non-Nebula peer gateway to the Nebula Device since the VPN tunnel was established. |
Outbound | This shows the amount of traffic that has gone through the VPN tunnel from the Nebula Device to the Non-Nebula peer gateway since the VPN tunnel was established. |
Tunnel up time | This shows how many seconds the VPN tunnel has been active. |
Last heartbeat | This shows the last date and time a heartbeat packet was sent to determine if the VPN tunnel is up or down. |
Client to site VPN login account See Remote Access VPN for information on configuring the VPN client settings on the Nebula Device. | |
User Name | This shows the VPN client’s login account name. |
Assigned IP | This shows the IP address assigned by the Nebula Device to the VPN client device for use within the VPN tunnel. |
Public IP | This shows the public IP address that the VPN client is using to connect to the site. |
Inbound | This shows the amount of traffic that has gone through the VPN tunnel from the VPN client to the Nebula Device since the VPN tunnel was established. |
Outbound | This shows the amount of traffic that has gone through the VPN tunnel from the Nebula Device to the VPN client since the VPN tunnel was established. |
Threat report | Select to view the report for the past day, week or month. Alternatively, select Custom range... to specify a time the report will span. You can also select the number of results you want to view in a table. Then, click Update. |
Email report | Click this button to send threat reports by email, change the logo and set email schedules. |
Location | This shows the location on the map where the blocked threats occurred by category. |
Threat detected by category | |
Category | This shows the name of the category to which the threat belongs. |
Domain/IP | This shows the domain name or IP address where the threat was encountered. Click the Domain/IP to display the individual category statistics table. |
Hits | This shows the amount of hits on a specific threat category. |
% Hits | This shows the percentage of the hit counts for the threat encountered by a specific category. |
Action | Click + Add to Exception to the domain name or IP address that will bypass the threat management category check. Click x Remove from Exception to remove the previously added domain name or IP address that will bypass the threat management category check. |
Threat detected by client | |
Description | This shows the name of the client device who encountered a threat. Click the name to display the individual client statistics table. |
IPv4 address | This shows the IPv4 address of the client device who encountered a threat. |
MAC address | This shows the MAC address of the client device who encountered a threat. |
Hits | This shows the number of threat hits of the client device. |
% Hits | This shows the percentage of the hit counts encountered by a specific client device. |
Action | Click Block client to prevent Internet connection to the wired and WiFi LAN client. Click Unblock Client to allow the previously blocked wired and WiFi LAN client to connect to the Internet. |
Content Filter report | Select to view the report for the past day, week or month. Alternatively, select Custom range... to specify a time the report will span. You can also select the number of results you want to view in a table. Then, click Update. |
Email report | Click this button to send content filter reports by email, change the logo, set email format and schedules. Then, click Save. |
y-axis | The y-axis shows the number of hits on web pages that the Nebula Device’s content filter service has blocked. |
x-axis | The x-axis shows the time period over which the web page is checked. |
Content Filter block by category | |
Category | This shows the name of the category to which the web page belongs. Click the Category to display the individual category statistics table. |
Hits | This shows the amount of hits on a specific content filter block category. |
% Hits | This shows the percentage of the hit counts that the Nebula Device’s content filter service has blocked by a specific category. |
Content Filter block by client | |
Description | This shows the name of the client device who’s web page was blocked by the Nebula Device’s content filter service. Click the name to display the individual client statistics table. |
IPv4 address | This shows the IPv4 address of the client device who’s web page was blocked by the Nebula Device’s content filter service. |
MAC address | This shows the MAC address of the client device who’s web page was blocked by the Nebula Device’s content filter service. |
Hits | This shows the number of content filter service blocks of the client device. |
