Configure WiFi Security with WPA2 Enterprise (for Nebula Access Points only)
This tutorial shows you how to configure WPA2 Enterprise for an SSID using any of the following authentication servers:
• Nebula Cloud server
• RADIUS server.
WPA2 Enterprise uses IEEE 802.1X for authentication of many users such as in a large organization.
Configure WPA2 Enterprise with Nebula Cloud Authentication / RADIUS Server Authentication
1 Go to Site-wide > Configure > Access points > SSID advanced settings.
2 Select the SSID to which the settings you configure here will be applied.
3 In Security options, select WPA2 in WPA Enterprise with.
4 To use NCC’s user database, select Nebula cloud authentication in WPA Enterprise with.
If your network has a RADIUS server for authentication, select My RADIUS server in WPA Enterprise with.
If you select My RADIUS server in step 4, enter the RADIUS server’s IP address/domain name in RADIUS server’s Host. Enter the Port number of the RADIUS server; the default is 1812. Enter up to 32 alphanumeric characters for the Secret password, which is the key to be shared between the external RADIUS server and the Nebula Device.
5 Then click Save.
Manage User Accounts
1 Go to Organization-wide > Organization-wide manage > Cloud authentication > User to view and manage the user accounts which are authenticated using the NCC user database or external RADIUS server.
2 Click +Add to create a new user account and fill in the user’s information in the Create user window. Then click Create user to save your changes and close the screen.
3 The click Save.
4 To check your settings, go to Site-wide > Configure > SSID settings.
For Nebula Cloud authentication, WPA2-Enterprise with Cloud-authentication is the encryption method shown on SSID advanced settings: WLAN security.
For RADIUS Server authentication, WPA2-Enterprise with MyRADIUS is the encryption method shown on SSID advanced settings: WLAN security.
