Monitor
Use the Monitor menus to check the site features logs and containment list of the Nebula Devices for the selected site. Please click the following links to go to the respective Nebula Devices Monitor menus.
• Access points (Section 5.2 on page 305)
• Security router (Section 7.2 on page 415)
• Mobile router (Section 10.4 on page 640)
• Security gateway (Section 9.2 on page 576)
Containment List
This screen shows a list of clients that are currently blocked in the site by the CDR security service. You can use this screen to release blocked clients. Click Site-wide > Monitor > Containment list to access this screen.
Label
Description
Search
Enter a MAC or IP address to filter the list of clients.
Time
This field displays the date and time CDR contained this client.
IP address
This field displays the IPv4 address of the client contained by CDR.
MAC address
This field displays the MAC address of the client contained by CDR.
User
This field displays the user name of a client contained by CDR who has been authenticated for Internet access. The field is blank if user authentication is not required.
Event type
This field displays details on the category of signature that triggered CDR: Web Filtering, Anti-Malware or IPS (IDP).
Containment
This field displays if the client is blocked, quarantined or just triggers an alert.
Time Remaining (mins.)
This field displays the amount of time left until this client is released by CDR.
Connect to
This field displays the description of the Access Point or the interface of the Nebula Device that the contained client is connected to.
Release/Add to Exempt List
Release
Select a client and then click this to release this client device from CDR containment.
Add to Exempt List
Select a client, select an IPv4 address or MAC address, and then click OK to release this client device from CDR containment. This client device’s IP or MAC address is exempt from future CDR checking.
Site Features Logs
This screen displays events from the Security Appliance within the selected site, such as CDR service events, alerts, and firmware management.
Click Site-wide > Monitor > Site features logs to access this screen.
Label
Description
Feature
Select the features that you want to view logs for.
Keyword
Enter a keyword to filter the list of log entries.
Category
Select the type of log messages you want to view. The available categories will depend on the features you have selected under Feature.
Range/Before
Select filtering options, set a date, and then click Search to filter log entries by date.
Range: Display log entries from the first specified date to the second specified date.
Before: Display log entries from the beginning of the log to the selected date.
Reset filters
Click this to return the search criteria to the previously saved time setting.
Search
Click this to update the list of logs based on the search criteria.
Newer/Older
Click to sort the log messages by most recent or oldest.
N Logs
This shows the number of log messages (N) in the list.
Export
Click this button to download the log list as a CSV or XML file to your computer.
Time
This shows the date and time when the log was recorded.
It uses the local time set for the site at Site-wide > Configure > Site settings.
Feature
Select the feature that created the log message.
Category
This shows the type of log message, for example “Block”. The available categories will depend on the feature.
Detail
This shows the details of the event.
*Click the Nebula Device name link for an Auto configuration recovery alert to go to Site-wide > Devices > Switches: Switch Details screen for more information.
Click this icon to display a greater or lesser number of configuration fields.
