Label | Description |
Tag | Select one or multiple sites and click this button to create a new tag for the sites or delete an existing tag. |
Delete | Select the sites and click this button to remove it. |
Search | Enter a key word as the filter criteria to filter the list of sites. |
Sites | This shows the number of sites in this organization. |
Over the last day | This shows how many clients are associated with the sites in this organization and the total amount of data transmitted or received by the clients in the past day. |
Export | Click this button to save the site list as a CSV or XML file to your computer. |
Status | This shows the status of Nebula Devices in the site. • Green: All Nebula Devices are online and have no alerts. • Amber: Some Nebula Devices have alerts. • Red: Some Nebula Devices are offline. • Gray: All Nebula Devices have been offline for 7 days or more. • White: No Nebula Devices. |
Name | This shows the descriptive name of the site. |
Usage | This shows the amount of data consumed by the site. |
Client | This shows the number of clients connected to Nebula Devices in the site. |
Tag | This shows the user-specified tag that is added to the site. |
Site Health | This shows the percentage of uptime in a given time interval to indicate the site’s network availability. • Green: 95 – 100% network uptime • Dark green: 75 – 95% network uptime • Brown: 50 – 75% network uptime • Red: < 50% network uptime • Grey: No uptime data |
Device | This shows the total number of Nebula Devices deployed in the site. |
Offline device | This shows the number of Nebula Devices which are added to the site but not accessible by the NCC now. |
% Offline | This shows what percentage of the connected clients are currently offline. |
![]() | Click this icon to display a greater or lesser number of configuration fields. |
Search | Enter a key word as the filter criteria to filter the list of tags. |
Site tags | This shows the number of site tags created and added to the sites in this organization. |
Over the last day | This shows the number of clients associated with the sites in this organization and the total amount of data transmitted or received by the clients in the past day. |
Export | Click this button to save the tag list as a CSV or XML file to your computer. |
Status | This shows the status of Nebula Devices in sites with the specified tag. • Green: All Nebula Devices are online and have no alerts. • Amber: Some Nebula Devices have alerts. • Red: Some Nebula Devices are offline. • Gray: All Nebula Devices have been offline for 7 days or more. • White: No Nebula Devices. |
Tag | This shows the name of the specified tag. |
Site | This shows the total number of sites with the specified tag. |
Offline device | This shows the number of offline Nebula Devices in all sites with the specified tag. |
Client | This shows the number of clients in sites with the specified tag. |
Usage | This shows the total amount of data consumed in all sites with the specified tag. |
Device | This shows the total number of Nebula Devices deployed to all sites with the specified tag. |
Offline site | This shows the number of offline sites with the specified tag. |
% Offline | This shows what percentage of all sites with the specified tag are currently offline. |
Search | Enter a key word as the filter criteria to filter the list of connected Nebula Devices. |
Devices | This shows the number of Nebula Devices assigned to the sites in this organization. |
Export | Click this button to save the Nebula Device list as a CSV or XML file to your computer. |
Status | This shows the status of the Nebula Device. • Green: The Nebula Device is online. • Amber: The Nebula Device recently had alerts. • Red: The Nebula Device was recently offline. • Gray: The Nebula Device has been offline for more than 6 days. |
Model | This shows the model number of the Nebula Device. |
Name | This shows the descriptive name of the Nebula Device. |
Site | This shows the name of the site to which the Nebula Device is connected. |
MAC address | This shows the MAC address of the Nebula Device. |
Tag | This shows the user-specified tag for the Nebula Device. |
Client | This shows the number of the clients which are currently connected to the Nebula Device. |
Usage | This shows the amount of data consumed by the Nebula Device. |
Serial number | This shows the serial number of the Nebula Device. |
Configuration status | This shows whether the configuration on the Nebula Device is up-to-date. |
Connectivity | This shows the Nebula Device connection status. The red time slot indicates the connection to the NCC is down, and the green time slot indicates the connection is up. Move the cursor over a time slot to see the actual date and time when a Nebula Device is connected or disconnected. |
Public IP | This shows the global (WAN) IP address of the Nebula Device. |
Search | Click to enter one or more key words as the search criteria to filter the list of logs. |
Range/Before | Select Range to set a time range or select Before to choose a specific date/time and the number of hours/minutes to display only the log messages generated within a certain period of time (before the specified date/time). The maximum allowable time range is 30 days. |
Search | Click this to update the list of logs based on the search criteria. |
Reset filters ![]() | Click this to return the search criteria to the previously saved time setting. |
Newer/Older | Click to view a list of log messages with the most recent or oldest message displayed first. |
This shows the total number of the log messages that match the search criteria. It also shows the date and time the very first log was created. | |
Export | Click this button to save the log list as a CSV or XML file to your computer. |
Time (UTC) | This shows the date and time in UTC+00:00 (or UTC+0) when the log was recorded. UTC is a standard time for use around the world (formerly known as Greenwich Mean Time or GMT). UTC is an international abbreviation that is neither French nor English. It means both "Temps Universel Coordonné" and "Coordinated Universal Time". |
Site Time | This shows the date and time of the site, to which the change was applied, when the log was recorded. |
Admin | This shows the name of the administrator who made the changes. |
Site | This shows the name of the site to which the change was applied. |
SSID | This shows the SSID name to which the change was applied. |
Page | This shows the name of the NCC menu in which the change was made. |
Label | This shows the reason for the log. |
Old value | This shows the old setting that was discarded and overwritten with the new attribute value. |
New value | This shows the new setting that was adopted. |
Name | Enter a descriptive name for the organization. |
Country | Select the country where the organization is located. ![]() |
Security | |
Idle timeout | Select ON and enter the number of minutes each user can be logged in and idle before the NCC automatically logs out the user. Select OFF if you do not want the NCC to log out idle users. |
Login IP ranges | Select ON and specify the IP address range of the computers from which an administrator is allowed to log into the NCC. Select OFF to allow any IP address of the computer from which an administrator can log into the NCC. |
Import certificate | |
Use my certificate | Select ON to import a certificate that can be used by connected Nebula Access Points in WPA2 authentication. |
Name | Enter a name for the certificate (up to 64 letters). |
File Path | Click to find the certificate file you want to upload. |
Import | Click this button to save a new certificate to the NCC. |
Password | Enter the certificate file’s password. |
Override device ownership | Select ON to prevent others from changing the ownership of the Nebula Device in your organization by simply scanning the QR code through the Nebula Mobile app. You can still transfer or unregister the Nebula Device through your myZyxel account. |
Delete this organization | Click the Delete organization button to remove the organization when it does not have any sites, Nebula Devices or users. ![]() |
Organization Status | |
Actions | Click this button to add licenses and/or Nebula Devices to the organization. Choose one of the following actions: • Add more devices: Add new Nebula Devices to the organization, by serial number and MAC address. For details, see Add Devices Screen. • Add more licenses: Add new licenses to the organization, by license key. For details, see Add Licenses Screen. • Install wizard: Add Nebula Devices and licenses to the organization, assign the licenses to the Nebula Devices, and then upgrade the organization if required. For details, see Install Wizard. |
Purchase License | Click this button to go to a window that will ask if you wish to be redirected to the Zyxel Circle web site (if the NCC account has a Circle account). If you do not have a Circle account, you can do the following: 1. Select what license to purchase and set the target expiration date to keep the Pro/Plus tier features/services running. 2. You may export the list of required licenses to your computer. 3. After calculating the license to purchase, click the Zyxel license marketplace (Check out) button to complete your purchase. Purchased licenses are directly assigned to Nebula Device(s). Unused licenses assigned to your organization will not be counted as it is not yet assigned to a Nebula Device. This button is available only for the Full (Delegated) administrator privilege or Owner administrator account with a registered Nebula Device(s). |
Upgrade Now | Click this button to upgrade the organization to Plus or Pro tier. The button is only available if you have a Plus or Pro license for every Nebula Device in the organization. |
Downgrade Now | Click this button to downgrade the organization from Plus or Pro to Base tier, or from Pro to Plus tier. All active NCC licenses in the organization will stay active and continue to count down to their expiry time. |
Organization type | This shows the licensing tier of the organization. Possible values are: Base, Plus Pack, Professional Pack, and Trial. |
NCC license | This shows whether there are any Nebula Devices with near expiring licenses. |
NSS/UTM license | This shows whether the current site has an active NSS or UTM license. |
Secure WiFi license | This shows whether the current site has an active Secure WiFi license. A Secure WiFi license unlocks the Remote AP feature. Remote AP allows users connected to an off-site (remote) AP to connect to on-site resources behind the Nebula Device through a secure IPSec VPN tunnel. |
Device status by expiration date | Click this button to select the data to be shown in the graph. Choose one from each of the following criteria: • All service name, Nebula Professional Pack, Nebula Plus Pack, Nebula Security Pack, UTM Security Pack, or Secure WiFi: select the category of licenses to display. • All device type, Access Point, Switch, or Security Gateway: select the category of Nebula Device to display. • Monthly, Quarterly, or Yearly: select the period of time to display. |
Device detail status | |
License type | Select the license type to filter your selection (Nebula Professional Pack, Nebula Plus Pack, Gold Security Pack, Nebula Security Pack, UTM Security Pack, Content Filter Pack, Secure WiFi, Connect & Protect). |
Device type | This shows the category of Nebula Device (Access Point, Switch, Security Appliance, Mobile Router) and Nebula Device model. |
# in org | This shows the total number of Nebula Devices of the specified category and model that are in the organization. |
# unlicensed (expired) | This shows the total number of Nebula Devices of the specified category and model that have: • No NCC Pro or Plus license. • An expired NCC Pro or Plus license. |
# near expiration in 90 days | This shows the total number of Nebula Devices of the specified category and model that have an NCC Pro or Plus license that will expire within 90 days. |
# expiration over 90 days | This shows the total number of Nebula Devices of the specified category and model that have an NCC Pro or Plus license that have more than 90 days before expiration. |
# inactive | This shows the total number of Nebula Devices of the specified category and model that have an NCC Pro or Plus license that has not been activated. |
template | Click this to download an XLSX file that you can use as a template to import a large number of Nebula Devices at once. Follow the instructions and formatting in the template to add the Nebula Device’s serial numbers and MAC addresses. |
import | Click this to upload a completed template XLSX file and import all Nebula Devices in the file. |
MAC address | Enter the MAC address of the new Nebula Device. |
Serial Number | Enter the serial number of the new Nebula Device. |
Name | Enter a name for the new Nebula Device. It can consist of 1 – 64 characters. |
Model | This shows the model number of the Nebula Device being added. |
License info | This shows the type of NCC license activated on the Nebula Device, if there is one. |
Expiration date | This shows the expiration date of the NCC license activated on the Nebula Device, if there is one. |
Assign licenses from inventory | Click here to assign unassigned licenses already in the organization to the Nebula Device. ![]() |
![]() | Click the remove icon to delete the entry. |
Add another device | Click this to add another Nebula Device to the organization. |
Acknowledge | Select this to confirm that your NCC account will be the owner of the new Nebula Devices. |
Finish | Click this to add the Nebula Devices to the organization. |
Cancel | Click this to close the screen without saving. |
template | Click this to download an XLSX file that you can use as a template to import a large number of licenses at once. Follow the instructions and formatting in the template to add the license keys. |
import | Click this to upload a completed template XLSX file and import all licenses in the file. |
License key | Enter the license key of the new license. |
License information | This shows the license type and validity period of the license being added. |
Add | Click this to add another license to the organization. |
Finish | Click this to add the license to the organization. |
N Access Point | This shows the total number of access points (N) in the organization. |
N Switch | This shows the total number of switches (N) in the organization. |
N Security Appliance | This shows the total number of Security Gateway devices (N) in the organization. |
N Mobile Router | This shows the total number of Mobile Router devices (N) in the organization. |
Actions | Select one or more Nebula Devices and then click this button to perform one of the following actions: Change organization: Moves the Nebula Device to an organization. The organizations must have the same owners. Change site assignment: Moves the selected Nebula Devices to a site, or remove them from their current site while leaving them in the organization. ![]() Remove from organization: Remove the Nebula Devices from NCC. You can manage the Nebula Devices in standalone mode, or re-add them to NCC later. Assign license: Assign licenses to the selected Nebula Devices. Undo assign: Unlink the inactive licenses from the associated Nebula Devices. After unlinking, the license will be categorized as unused in Inventory. An inactive license is a license that has been assigned to a Nebula Device but is not yet in use or queued. Transfer license: Moves the unused licenses linked to a Nebula Device to another Nebula Device. Nebula Devices can be in the same organization or in a different organization. The Nebula Devices must have the same owner. Bundled, Trial, and Promotion licenses cannot be transferred. Purchase license: Select what license to purchase and target expiration date to keep the Pro/Plus tier features/services running. You may export the list of required licenses to your computer. Then click the Zyxel license marketplace (Check out) button to complete your purchase. Unused licenses assigned to your organization will not count as it is not yet assigned to a Nebula Device. This button is available only for the Organization (Delegated) or Owner administrator account with a registered Nebula Device(s). |
In use / Unused / Both | Select to display the Nebula Device currently in a site (In use), not current (Unused), or show all (Both). |
Search | Enter a keyword or specify one or more filter criteria to filter the list of Nebula Devices. |
+ Add | Add one or more new Nebula Devices to the organization, by entering the Nebula Device’s MAC address and serial number. For details, see Add Devices Screen. |
Select an entry’s check box to select a specific Nebula Device. Otherwise, select the check box in the table heading row to select all Nebula Devices. | |
Device | This shows the hostname of the Nebula Device. |
Device type | This shows the category of Nebula Device (Access Point, Switch, Security Appliance, Firewall, Mobile Router) and Nebula Device model. |
Site | This shows the site that the Nebula Device is currently in. If the Nebula Device is not in any site, the value is blank. |
Model | This shows the Nebula Device’s model. |
Serial Number | This shows the Nebula Device’s serial number. |
MAC address | This shows the MAC address of the Nebula Device’s first Ethernet port. |
Device tag | This shows the tag created and added to the Nebula Device. |
Claim date | This shows the date on which the Nebula Device was added to NCC. If the Security Firewall has NOT yet connected to NCC (see Supported Nebula Devices for the list of Security Firewalls): • Native mode. Click this button and select Nebula Native mode in the Deployment Method. Follow the instructions to connect the Security Firewall to NCC. • Waiting ZTP will be shown if Native mode is not available. Click the Waiting ZTP button and select Zero Touch Provisioning in Deployment Method to configure the ZTP settings. |
Unused / In use | This shows Unused if the Nebula Device is not assigned to a site, or In use if the Nebula Device is currently in a site. |
Country | This shows the country in which the Nebula Device is located. |
License expiration date | This shows the date on which the Nebula Device’s NCC license will expire. |
License info | This shows the type of NCC license assigned to the Nebula Device. ![]() |
Action | Select one or more Nebula Devices and then click this button to perform one of the following actions: Change organization: Moves the Nebula Device to an organization. The organizations must have the same owners. Change site assignment: Moves the selected Nebula Devices to a selected site, or removes them from their current site while leaving them in the organization. ![]() Remove from organization: Remove the Nebula Devices from NCC. You can manage the Nebula Devices in standalone mode, or re-add them to NCC later. Assign license: Assign unassigned licenses to the selected Nebula Devices. Undo assign: Unlink the inactive licenses from the associated Nebula Devices. After unlinking, the license will be categorized as unused in Inventory. An inactive license is a license that has been assigned to a Nebula Device but is not yet in use or queued. Transfer license: Moves unused licenses linked from one Nebula Device to another Nebula Device. The Nebula Devices can be in the same organization or in a different organization. The Nebula Devices must have the same owner. Bundled, Trial, and Promotion licenses cannot be transferred. |
N assigned | This shows the total number of licenses (N) in the organization that are assigned to a Nebula Device and activated. |
N unused (Pro Pack, 1MO/1YR/2YR/4YR/7YR) or N unused (Plus Pack, 1MO/1YR/2YR) | This shows the total number of Nebula Professional Pack or Nebula Plus Pack licenses (N) in the organization that are not assigned to a Nebula Device. |
N unused (UTM Pack, 1MO/1YR/2YR) | This shows the total number of UTM Security Pack licenses (N) in the organization that are not assigned to a Nebula Device. |
Actions | Select one or more Nebula Devices and then click this button to perform one of the following actions: Change organization: Moves the selected licenses to an organization. The organizations must have the same owners. Assign License: Assign the selected licenses to one or more Nebula Devices. Only the licenses applicable for the Nebula Device can be selected. Undo assign: Unlink the inactive licenses from the associated Nebula Devices. After unlinking, the license will be categorized as unused in Inventory. An inactive license is a license that has been assigned to a Nebula Device but is not yet in use or queued. Transfer license: Moves the unused licenses linked to a Nebula Device to another Nebula Device. The Nebula Devices can be in the same organization or in a different organization. The Nebula Devices must have the same owner. Bundled, Trial, and Promotion licenses cannot be transferred. |
Search | Enter a keyword or specify one or more filter criteria to filter the list of licenses. |
N licenses | This shows the total assigned and unassigned licenses in the organization. |
Show expired licenses | Click this to display licenses that are past their validity. |
+ Add | Add one or more new licenses to the organization, by entering their license keys. For details, see Add Licenses Screen. |
Export | Click this to save the license list as a CSV or XML file to your computer. |
License Key | This shows the key of license, including bundled licenses. |
Service | This shows the service that license is for, for example “Nebula Professional Pack”. |
License states | This shows the current status of the license: • Active: The license is assigned to a specific Nebula Device and activated. • Inactive: The license is assigned to a specific Nebula Device but not activated. • Expired: The license is past its validity. • Queued: The license is assigned to a specific Nebula Device, and the license is waiting for the currently active license to expire. • Unused: The license is not assigned to a specific Nebula Device. |
License expiration date | This shows the date on which the license will expire. Queued means there are multiple licenses assigned to the Nebula Device, and the license is waiting for the currently active license to expire. |
Remaining days | This shows how days remain until the license expires. |
Claim date | This shows the date on which the license was added to NCC. If the Security Firewall has NOT yet connected to NCC: • Native mode. Click this button and select Nebula Native mode in Deployment Method. Follow the instructions to connect the Security Firewall to NCC. • Waiting ZTP will be shown if Native mode is not available. Click the Waiting ZTP button and select Zero Touch Provisioning in Deployment Method to configure the ZTP settings. |
Activate date | This shows the date on which the license was activated. |
Associated device | This shows the name and model of the Nebula Device that the license is assigned to. |
Associated site | This shows the name of the site that the license is being used in. Click the site to go to its dashboard. |
Action | Click this button to perform the following actions: Change organization: Moves the selected licenses to an organization. The organizations must have the same owners. Assign License: Assign the selected licenses to one or more Nebula Devices. Only the licenses applicable for the Nebula Device can be selected. Undo assign: Unlink the inactive licenses from the associated Nebula Devices. After unlinking, the license will be categorized as unused in Inventory. An inactive license is a license that has been assigned to a Nebula Device but is not yet in use or queued. Transfer license: Moves the unused licenses linked to a Nebula Device to another Nebula Device. The Nebula Devices can be in the same organization or in a different organization. The Nebula Devices must have the same owner. Bundled, Trial, and Promotion licenses cannot be transferred. |
trial License | Associated Features or Nebula Devices |
Nebula Pro Pack Trial | This is for advanced features, except open API access, within the Nebula Device’s organization. See General Settings for more information on open API access. |
MSP Pack Trial | This is for new NCC accounts or NCC accounts that have not used MSP before. This allows you to manage multiple organizations. |
Gold Security Pack Trial | This is for ATP devices and USG FLEX devices except USG20-VPN / USG20W-VPN / USG FLEX 50. ![]() |
Secure WiFi Trial | This is for remote APs (access points) to securely connect a ZyWALL ATP / USG FLEX (except USG FLEX 50) in the office. |
Content Filter Pack Trial | This is for USG FLEX 50 /USG20-VPN / USG20W-VPN devices. |
Connect & Protect (CNP) Trial | This allows you to manage small business WiFi hotspots using an NWA1123-ACv3, WAC500, WAC500H, NWA110AX, NWA210AX, WAX510D, WAX610D, WAX630S, or WAX650S. |
Actions | Click this to perform one of the following actions: • Activate trial for all: select this to start using all trial licenses available for your organization. Then click Confirm to continue. • Deactivate trial for all: select this to cancel all trial licenses currently in use in your organization. Then click Confirm to continue. ![]() |
(Status) | The status displays next to the name of a trial license. If no status displays, it means you can activate the trial license. The trial license can be used on the Nebula Devices within the organization. Click Activate to start using the services of the trial license. ![]() |
IN PROGRESS | The 30-day countdown for the trial license has begun. Click Deactivate if you want to cancel the trial license. ![]() |
TRIAL EXPIRED | You have previously activated a trial or standard license and the license period has ended. |
CANCELED | You have deactivated the trial license during the 30-day trial period. |
Activate | Click this to start using the 30-day trial license. Then click Confirm to continue. |
Deactivate | Click this to cancel the 30-day trial license anytime before it expires. Then click Confirm to continue. |
Keyword | Enter a keyword or specify one or more filter criteria to filter the list of log entries. |
Range / Before | Select a filtering option, set a date, and then click Search to filter log entries by date. Range: Display log entries from the first specified date to the second specified date. Before: Display log entries from the beginning of the log to the selected date. |
Newer / Older | Click to view the list of log messages with the most recent or oldest message displayed first. |
Date and time | This shows the date and time in UTC+00:00 (or UTC+0) when the log was recorded. UTC is a standard time for use around the world (formerly known as Greenwich Mean Time or GMT). UTC is an international abbreviation that is neither French nor English. It means both "Temps Universel Coordonné" and "Coordinated Universal Time". |
Action | This shows the action that triggered the log entry. |
Before | This shows the old setting or state that was overwritten with the new value. |
After | This shows the new setting or state. |
Admin | This shows the name of the NCC administrator account that made the changes. |
Keyword | Enter a keyword or specify one or more filter criteria to filter the list of purchased license entries. |
N purchases | This displays the total purchased licenses in the organization. |
Order ID | This displays a unique code that identifies the order. Clicking this link will take you to the Marketplace > Order History screen. |
Purchase date | This displays the date that the order was created. |
# licenses | This displays the number of licenses purchased for the specified license type. |
Purchase by | This displays the email address of the NCC account that created the order. |
Status | This displays the current status of the order. • Done: The order has been paid for and the license was successfully activated on the target Nebula Device. • Processing: The license activation on the target Nebula Device is still under process. • Failed: The license was not successfully activated on the target Nebula Device. |
Export | Click this to download the order details as a CSV or XML file to your computer. This includes the Order ID and each license’s assigned device information. |
Activation | Click this button to Activate/Deactivate the selected accounts. Then click Update. |
Force logout | Click this button to force the selected accounts to log out of the NCC. |
Delete | Click this button to remove the selected accounts. |
Search | Specify your desired filter criteria to filter the list of administrator accounts. |
administrators | This shows the number of administrator accounts in the list. |
Change owner | This button is only available if you are the organization owner. Click this button to transfer ownership of the organization to another user account. The new owner account must be an organization full administrator. After transferring ownership, NCC performs the following actions: • Changes your account from organization owner to organization full administrator. • Transfers all Nebula Devices and licenses in the organization to the new owner. • Sends the new owner an email, notifying them of the change. |
Import | Click this button to create administrator accounts in bulk by importing a complete list of all new administrators in an Excel file. |
Add | Click this button to create a new administrator account. See Create/Update Administrator. |
Name | This shows the name of the administrator account. |
Email address | This shows the email address of the administrator account. |
Merged privilege | This shows the final privilege the account has in the organization, when organization privileges configured on different screens are combined and prioritized. Organization privileges can be configured on the following screens; the highest privilege level takes priority: • MSP > Configure > Admins & teams > Admins • MSP > Configure > Admins & teams > Teams • Group-wide > Configure > Administrators • Organization-wide > Configure > Administrators For more information, see Administrator Privilege Priority. |
Privilege | This shows whether the administrator account has read-only, monitor-only, guest ambassador, or read and write (full) access to the organization and sites. Installer indicates that the administrator account can register Nebula Devices at a site. Owner indicates that the administrator account is the creator of the organization, who has full access to that organization and cannot be deleted by other administrators. Organization (Delegated) means that the administrator account has delegated owner privileges. This type of account can perform all of the same actions as the organization owner, except for the following: • Delete organization • Transfer organization ownership • Assign delegate owner privileges to an administrator account. |
Account status | This shows whether the administrator account has been validated (OK). It shows Deactivated if an administrator account has been created but cannot be used. This may happen since you can only have up to five active administrator account on Nebula (free). |
Last access time | This shows the last date and time traffic was sent from the administrator account. |
Create date | This shows the date and time the administrator account was created. |
Status change date | This shows the last date and time the administrator account status was changed. |
Name | Enter a descriptive name for the administrator account. |
Email | Enter the email address of the administrator account, which is used to log into NCC. This field is read-only if you are editing an existing account. |
Organization access | Set the administrator account’s access to the organization. When an administrator account has read and write (Full) access, the administrator can create or delete other administrator accounts, create or delete a site, and add or renew licenses for Nebula Devices in the organization. ![]() If you select Read-only, the administrator account can be the organization administrator (that has no write access to the organization) and also be a site administrator. If you select None, the administrator account can only be a site administrator. |
Delegate owner’s authority | This setting is only available when Organization access is set to Full. Select this setting to grant delegate owner privileges to an organization full administrator account. An account with delegate owner privileges can perform all of the same actions as the organization owner, except for the following: • Delete organization • Transfer organization ownership • Assign delegate owner privileges to an administrator account. |
Activate | Select Yes to enable the account or No to temporarily disable the account. |
YES, I want to do it. | The check box displays only when an administrator that has full access to the organization selects No in the Activate field to disable his/her own account. ![]() |
Site | This field is available only when you set the account’s organization access to Read-only or None. Select the site to which you want to set the account’s access. You can also select the site tag created using the Organization-wide > Monitor > Overview: Sites screen. |
Privilege | This field is available only when you set the account’s organization access to Read-only or None. Set the administrator account’s access to the site. You can select from Read-only, Monitor-only, Guest Ambassador, Installer and Full (read and write). An administrator account that has Guest Ambassador access can create, remove or manage guest accounts using the Cloud Authentication screen (see Cloud Authentication). Installer access allows an administrator to register Nebula Devices at this site. |
Add | Click this button to create a new entry in order to configure the account’s access to another site. |
Close | Click this button to exit this screen without saving. |
Create admin/Update admin | Click this button to save your changes and close the screen. |
Account Type | Description | Authentication Methods |
User | The user account can gain access to the networks by authenticating using a pre-created user name and password, or their email address. This type of user account also supports DPPSK and two-factor authentication. | • WiFi authentication (WPA-Enterprise) • Network access through captive portal • VPN Access • WiFi authentication + network authentication through DPPSK |
MAC | The Nebula Device account that can gain access to the networks by authenticating using its MAC address. | • MAC-based Nebula Device authentication (combined with DPPSK) |
DPPSK | A user that can gain access to the network using a unique dynamic Personal Pre-Shared key that is linked to their user account. | • WiFi authentication + network authentication through DPPSK |
Authorization | Select one or more than one user account and click this button to configure the authorization settings for the selected user accounts. |
Remove users | Select one or more than one user account and click this button to remove the selected user accounts. |
VPN access | Select one or more than one user account and click this button to configure whether the accounts can be used to connect to the organization’s networks through VPN. |
VLAN attribute | Select one or more than one user account and click this button to assign the users to a specific VLAN ID, or clear the VLAN ID. Then click Update. ![]() |
Print | Click this button to print information about each selected user account, such as their user name and password. |
Search users | Enter a key word as the filter criteria to filter the list of user accounts. |
N User | This shows how many user accounts (N) match the filter criteria and how many user accounts of the selected type are created in total. |
Import | Click this button to create user accounts in bulk by importing a complete list of all new users in an Excel file. |
Add | Click this button to create a new user account. See Create/Update User Account. |
Export | Click this button to save the account list as a CSV or XML file to your computer. |
Email | This shows the email address of the user account. |
Username | This shows the user name of the user account. |
Description | This shows the descriptive name of the user account. |
802.1X | This shows whether 802.1X (WPA-Enterprise) authentication is enabled on the account. |
VPN access | This shows whether the accounts can be used to connect to the organization’s networks through VPN. |
Authorized | This shows whether the user has been authorized or not (No). If the user is authorized, it shows All sites or the name of the site to which the user is allowed access. |
Expire in (UTC) | This shows the date and time that the account expires. This shows -- if authentication is disabled for this account. This shows Never if the account never expires. This shows Multiple value if the account has different Expire in values across different sites. |
Login by | This shows whether the user needs to log in with the email address and/or user name. |
DPPSK | This shows the account’s dynamic personal pre-shared key (DPPSK), if one is set. |
VLAN assignment | This field is available only when the account type is set to User. This shows the VLAN assigned to the user. |
2FA Status | This shows whether the account has set up two-factor authentication yet. |
Bypass 2FA | This shows whether the account is allowed to bypass two-factor authentication, if two-factor authentication is enabled on a captive portal or VPN gateway. |
Authorized by | This shows the email address of the administrator account that authorized the user. If the account has been authorized by different admins across different sites, it shows Multiple value. |
Created by | This shows the email address of the administrator account that created the user. |
Created at | This shows the date and time that the account was created. |
Account type | This shows the type of the user account. |
Email | Enter the email address of the user account, which is used to log into the networks. |
Username | Enter a user name for this account. ![]() |
Description | Enter a descriptive name for the account. |
Password | Enter the password of this user account. It can consist of 4 – 31 alphanumeric characters. You can click Generate to have NCC create a password for the account automatically. |
DPPSK | Enter a dynamic personal pre-shared key (DPPSK) for this DPPSK user account, if you want to be able to authenticate using DPPSK in addition to a user name and password. It can consist of 8 – 31 alphanumeric characters. You can click Generate to have the NCC create a DPPSK for the account automatically. |
802.1X | Select this to allow the account to be used for single sign-on (SSO) network and WiFi authentication using 802.1X (WPA-Enterprise). |
VPN Access | Select this to allow the account to be used to connect to the organization’s networks through VPN. |
Authorized | Set whether you want to authorize the user of this account. You can select to authorize the user’s access to All Sites or Specified Sites in the organization. If you select Specified Sites, a field displays allowing you to specify the sites to which the user access is authorized. |
Expire in | This field is available only when the user is authorized. Click Change to specify the number of minutes/hours/days/weeks the user can be logged into the network in one session before the user of this account has to log in again. ![]() Otherwise, select Never and the user of this account will never be logged out. |
Login by | Select whether the user needs to log in with the email address and/or user name. |
VLAN assignment | This allows you to assign a user to a specific VLAN based on the user credentials instead of using a RADIUS server. |
Bypass two-factor authentication | This shows whether the account is allowed to bypass two-factor authentication, if two-factor authentication is enabled on a captive portal or VPN gateway. |
Email account information to user | Select this to send a copy of the information on this screen to the account email address, after the account has been created. |
Print | Click this button to print the account information. |
Create user | Click this button to save your changes and close the screen. |
Authorization | Select one or more than one account and click this button to configure the authorization settings for the selected user accounts. |
Add | Click this button to create a new user account. See Create/Update MAC Account. |
MAC address | This shows the MAC address of the user account. |
Account type | This shows the type of user account: USER, MAC, or DPPSK. |
MAC address | Enter a MAC address for this account. |
Authorized | Set whether you want to allow the user of this account access to sites. Select All Sites or Specified sites to allow the user access to all or some sites in the organization. If you select Specified sites, a field displays allowing you to specify the sites to which the user access is authorized. Select Not authorized to prevent the user access to all the sites in the organization. |
Expires | Specify the number of minutes/hours/days/weeks the user has access to site(s) in the organization. |
Print | Click this button to print the unique dynamic personal pre-shared key (DPPSK) and expiry time of each selected user account. The account details can be cut into cards, and then given to users in order to grant them WiFi network access. ![]() |
N Users | This shows how many user accounts (N) match the filter criteria and how many user accounts of the selected type are created in total. |
Add | Click this button to create a single new account, or a batch of accounts. • Single DPPSK: See Add/Edit DPPSK Account. • Batch create DPPSK: See Batch Create DPPSK Accounts. |
DPPSK | This shows the account’s dynamic personal pre-shared key (DPPSK). |
VLAN ID | This shows the VLAN assigned to the account. |
Username | Enter a user name for this account. |
DPPSK | Enter a dynamic personal pre-shared key (DPPSK) for this DPPSK user account. It can consist of 8 – 31 alphanumeric characters. You can click Generate to have the NCC create a DPPSK for the account automatically. |
VLAN id | Enter the ID of a VLAN to assign a user to a specific VLAN. |
Number of accounts | Enter how many DPPSK user accounts you want to create. |
VLAN id | Assign the users to a specific VLAN based on the user’s dynamic personal pre-shared key (DPPSK). |
E-mail account info to | Send a copy of each user account’s dynamic personal pre-shared key (DPPSK) and expiry date to the specified email address. This information is in a printable format. The expiry date includes a time and date in UTC format. |
Synchronization | |
Settings | Specify whether general site configuration or just SSID settings of a site will be propagated to other sites. Click What will be synchronized? to view detailed information. |
From source site | Select the site from which you want to copy its site configuration to other sites. |
To Site(s) | Select one or more sites to which you want to import the copied site configuration. You can also select the site tags created using the Organization > Monitor > Overview: Sites screen. |
Sync | Click this button to start synchronizing configuration settings between the selected sites. |
Switch settings clone | |
From source device | Select the Nebula Switch from which you want to copy its Switch port settings to other Nebula Devices. |
To device(s) | Select one or more Nebula Switches to which you want to import the copied Switch port settings. ![]() |
Clone | Click this button to start synchronizing Switch port settings between the selected Nebula Devices. |
Backup & Restore ![]() | |
Site(s) settings | You can create up to three site configuration backups for the organization. The NCC automatically creates and saves one backup when you perform configuration restoration. The automatic backup cannot be deleted. |
Backup | This shows the index number of the site configuration backup. |
Description | This shows the descriptive name of the backup. ![]() |
Date (UTC) | This shows the date and time the backup was saved on the NCC server. |
Admin | This shows the name of the administrator account who performed the backup. |
Remove | Click the remove icon to delete the backup. |
Add | Click this button to create a new configuration backup of all the sites in the organization. |
Restore from backup | Select the backup you want to restore. |
Restore to site(s) | Select one or more sites to which you want to restore the specified configuration backup. |
Restore | Click this button to overwrite the settings of the sites with the selected configuration backup. |
Switch settings | At the time of writing, only one backup is allowed per Nebula Device. |
Backup | This shows the index number of the Switch configuration backup. |
Switch | This shows the name of the Switch. |
Model | This shows the model number of the Switch. |
Add | Click this button to create a new configuration backup of a specific Switch. This button is selectable only when you have at least one Switch in the organization. |
Restore to device(s) | Select one or more Nebula Switches to which you want to restore the specified configuration backup. ![]() |
Restore | Click this button to overwrite the settings of the Switches with the selected configuration backup. |
Create | Click this button to create a new configuration template. You can copy settings from an existing site or configuration template, or have a new template with default settings. It is optional to bind one or more sites to the template when you are creating a template. ![]() |
Delete | Click this button to remove the selected templates. A window pops up asking you to confirm that you want to delete the templates. If you remove a template that is being used by a site, the site will be unbound from the template automatically and retain the settings previously applied from the template. |
Search | Enter a key word as the filter criteria to filter the list of templates. |
Templates | This shows how many templates match the filter criteria and how many templates are created in total. |
Name | This shows the name of the template. |
# Bound sites | This shows the number of the sites bound to the template. |
Bound sites | This shows the name of the sites bound to the template. |
Bind additional site | Click this button to bind more sites to the template. A window displays. Select the name of the sites in the Target sites field and click Bind. |
Unbind | Click this button to remove the selected sites from the template. The site which is unbound from the template still retains the settings applied from the template. |
Sites | This shows how many sites match the filter criteria and how many sites are bound to the template in total. |
Name | This shows the name of the site bound to the template. |
Tag | This shows the tags added to the site. |
Device | This shows the number of Nebula Devices which are assigned to the site. |
Local override | This shows which settings in the template do not apply to the site. |
Security profile sync | |
Enabled | Click this to enable or disable security profile sync for the organization. |
Sync sites | Select one or more sites that you want to sync the security settings on this screen to. Select All sites to sync security settings with all sites in the organization. ![]() |
Content Filtering | |
Drop connection when there is an HTTPS connection with SSL v3 (or previous version) | Select On to have the Security Gateway block HTTPS web pages using SSL V3 or a previous version. |
Denied Access Message | Enter a message to be displayed when content filter blocks access to a web page. Use up to 127 characters (0–9a–zA–Z;/?:@&=+$\.–_!~*'()%,”). For example, “Access to this web page is not allowed. Please contact the network administrator”. It is also possible to leave this field blank if you have a URL specified in the Redirect URL field. In this case if the content filter blocks access to a web page, the security gateway just opens the web page you specified without showing a denied access message. |
Redirect URL | Enter the URL of the web page to which you want to send users when their web access is blocked by content filter. The web page you specify here opens in a new frame below the denied access message. Use “http://” or “https://” followed by up to 262 characters (0–9a–zA–Z;/?:@&=+$\.-_!~*'()%). For example, http://192.168.1.17/blocked access. |
Enabled | Select the check box to enable the content filtering profile. |
Description | Enter a description for this profile. |
![]() | Click this icon to change the profile settings. |
![]() | Click this icon to remove the profile. |
Add | Click this to create a content filtering profile. See Create a Content Filtering Profile for more information. |
Application Patrol Application profiles | |
Name | Enter a name for this profile for identification purposes. |
Add | Click this icon to create an application patrol profile. See Add Application Patrol Profile for more information. |
DNS/URL Threat Filter | |
Log | Select whether to have the Nebula Device generate a log (log), log and alert (log alert) or not (no) when the policy is matched to the criteria listed above. |
DNS Threat Filter | Select On to turn on the rule. Otherwise, select Off to turn off the rule. |
DNS Threat Filter policy | Select Pass to have the Nebula Device allow the DNS query packet and not reply with a DNS reply packet containing a default or custom-defined IP address. Select Redirect to have the Nebula Device reply with a DNS reply packet containing a default or custom-defined IP address. |
DNS Threat Filter Redirect IP | Enter the IP address to have the Nebula Device reply with a DNS reply packet containing a default or custom-defined IP address when a DNS query packet contains an FQDN with a bad reputation. The default IP is the dnsft.cloud.zyxel.com IP address. If you select a custom-defined IP, then enter a valid IPv4 address in the text box. |
URL Threat Filter | Select On to turn on the rule. Otherwise, select Off to turn off the rule. |
URL Threat Filter Policy | Select Pass to allow users to access web pages that the external web filtering service has not categorized. Select Block to prevent users from accessing web pages that the external web filtering service has not categorized. When the external database content filtering blocks access to a web page, it displays the denied access message that you configured in the Content Filter General screen along with the category of the blocked web page. Select Warn to display a warning message before allowing users to access web pages that the external web filtering service has not categorized. |
URL Threat Filter Denied Access Message | Enter a message to be displayed when content filter blocks access to a web page. Use up to 127 characters (0–9a–zA–Z;/?:@&=+$\.-_!~*'()%,”). For example, “Access to this web page is not allowed. Please contact the network administrator”. It is also possible to leave this field blank if you have a URL specified in the Redirect URL field. In this case if the content filter blocks access to a web page, the Nebula Device just opens the web page you specified without showing a denied access message. |
URL Threat Filter Redirect URL | Enter the URL of the web page to which you want to send users when their web access is blocked by content filter. The web page you specify here opens in a new frame below the denied access message. Use “http://” or “https://” followed by up to 262 characters (0–9a–zA–Z;/?:@&=+$\.-_!~*'()%). For example, http://192.168.1.17/blocked access. |
Test Threat Category | Enter a URL using http://domain or https://domain and click the Test button to check if the domain belongs to a URL threat category. |
Category List | These are categories of web pages based on their content. Select categories in this section to control access to specific types of Internet content. |
Block list | Sites that you want to block access to, regardless of their content rating, can be blocked by adding them to this list. Enter host names such as www.bad-site.com into this text field. Do not enter the complete URL of the site – that is, do not include “http://”. All sub-domains are also blocked. For example, entering “bad-site.com” also blocks “www.badsite.com”, “partner.bad-site.com”, “press.bad-site.com”, and so on. You can also enter just a top level domain. For example, enter .com to block all .com domains. Use up to 127 characters (0–9 a–z). The casing does not matter. |
Allow list | Sites that you want to allow access to, regardless of their content rating, can be allowed by adding them to this list. Enter host names such as www.good-site.com into this text field. Do not enter the complete URL of the site – that is, do not include “http://”. All sub-domains are allowed. For example, entering “zyxel.com” also allows “www.zyxel.com”, “partner.zyxel.com”, “press.zyxel.com”, and so on. You can also enter just a top level domain. For example, enter .com to allow all .com domains. Use up to 127 characters (0–9 a–z). The casing does not matter. |
URL Threat Filter external block list | The Nebula Device uses black list entries stored in a file on a web server that supports HTTP or HTTPS. The Nebula Device blocks incoming and outgoing packets from the black list entries in this file. |
Enabled | Select this to have the Nebula Device block the incoming packets that come from the listed addresses in the block list file on the server. |
Name | Enter an identifying name for the block list file. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. |
External DB | Enter the exact file name, path and IP address of the server containing the block list file. The file type must be ‘txt’. For example, http://172.16.107.20/blacklist-files/myip-ebl.txt The server must be reachable from the Nebula Device. |
Description | Enter a description of the block list file. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. |
![]() | Click this icon to remove the entry. |
Add | Click this button to create a new entry. |
Schedule update | The signatures for DNS Filter and URL Threat Filter are the same. These signatures are continually updated as new malware evolves. New signatures can be downloaded to the Nebula Device periodically if you have subscribed for the URL Threat filter signatures service. You need to create an account at myZyxel, register your Nebula Device and then subscribe for URL Threat filter service in order to be able to download new signatures from myZyxel. Select Daily to set the time of the day, or Weekly to set the day of the week and the time of the day. Schedule signature updates for a day and time when your network is least busy to minimize disruption to your network. |
IP Reputation | |
Enabled | Select this option to turn on IP blocking on the Nebula Device. |
Log | Select this option to create a log on the Nebula Device when the packet comes from an IPv4 address with bad reputation. |
Policy | Select Pass to have the Nebula Device allow the packet to go through. Select Block to have the Nebula Device deny the packets and send a TCP RST to both the sender and receiver when a packet comes from an IPv4 address with bad reputation. |
Threat level threshold | Select the threshold threat level to which the Nebula Device will take action (High, Medium and above, Low and above). The threat level is determined by the IP reputation engine. It grades IPv4 addresses. • High: an IPv4 address that scores 0 to 20 points. • Medium and above: an IPv4 address that scores 0 to 60 points. • Low and above: an IPv4 address that scores 0 to 80 points. For example, a score of “10” will cause the Nebula Device to take action whether you set the Threat level threshold at High, Medium and above, or Low and above. But a score of “61” will not cause the Nebula Device to take any action if you set the Threat level threshold at Medium and above. |
Test Category | Enter an IPv4 address of a website, and click the Test button to check if the website associates with suspicious activities that could pose a security threat to users or their computers. |
Category list | Select the categories of packets that come from the Internet and are known to pose a security threat to users or their computers. |
Block list | Sites that you want to block access to, regardless of their content rating, can be blocked by adding them to this list. Add the IPv4 addresses that the Nebula Device will block the incoming packets. |
Allow list | Sites that you want to allow access to, regardless of their content rating, can be allowed by adding them to this list. Add the IPv4 addresses that the Nebula Device will allow the incoming packets. |
External block list | |
Enabled | Select this check box to have the Nebula Device block the incoming packets that come from the listed addresses in the block list file on the server. |
Name | Enter the identifying name for the block list file. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long. |
External DB | Enter the file name, path and IP address of the server containing the block list file. For example, http://172.16.107.20/blacklist-files/myip-ebl.txt |
Schedule update | New IP reputation signatures can be downloaded to the Nebula Device periodically if you have subscribed for the IP reputation signatures service.You need to create an account at myZyxel, register your Nebula Device and then subscribe for IP reputation service in order to be able to download new signatures from myZyxel. Select Daily to set the time of the day, or Weekly to set the day of the week and the time of the day. Schedule signature updates for a day and time when your network is least busy to minimize disruption to your network. |
Anti-Malware | |
Enabled | Select On to turn on the rule. Otherwise, select Off to turn off the rule. |
Log | Select whether to have the Nebula Device generate a log when the policy is matched to the criteria listed above. |
Scan mode | |
Express mode | In this mode you can define which types of files are scanned using the File Type For Scan fields. The Nebula Device then scans files by sending each file’s hash value to a cloud database using cloud query. This is the fastest scan mode. |
Stream mode | In this mode the Nebula Device scans all files for viruses using its anti-malware signatures to detect known virus pattens. This is the deepest scan mode. |
Hybrid mode | In this mode you can define which types of files are scanned using the File Type For Scan fields. The Nebula Device then scans files by sending each file’s hash value to a cloud database using cloud query. It also scans files using anti-malware signatures, and Threat Intelligence Machine Learning. This mode combines Express Mode and Stream Mode to offer a balance of speed and security. |
Cloud Query | Select the Cloud Query supported file types for the Nebula Device to scan for viruses. |
Block list | This field displays the file or encryption pattern of the entry. Enter a file pattern that would cause the Nebula Device to log and modify this file. •Use up to 80 characters. Alphanumeric characters, underscores (_), dashes (-), question marks (?) and asterisks (*) are allowed. •A question mark (?) lets a single character in the file name vary. For example, use “a?.zip” (without the quotation marks) to specify aa.zip, ab.zip and so on. •Wildcards (*) let multiple files match the pattern. For example, use “*a.zip” (without the quotation marks) to specify any file that ends with “a.zip”. A file named “testa.zip would match. There could be any number (of any type) of characters in front of the “a.zip” at the end and the file name would still match. A file named “test.zipa” for example would not match. •A * in the middle of a pattern has the Nebula Device check the beginning and end of the file name and ignore the middle. For example, with “abc*.zip”, any file starting with “abc” and ending in “.zip” matches, no matter how many characters are in between. •The whole file name has to match if you do not use a question mark or asterisk. •If you do not use a wildcard, the Nebula Device checks up to the first 80 characters of a file name. |
Allow list | Enter the file or encryption pattern for this entry. Specify a pattern to identify the names of files that the Nebula Device should not scan for viruses. •Use up to 80 characters. Alphanumeric characters, underscores (_), dashes (-), question marks (?) and asterisks (*) are allowed. •A question mark (?) lets a single character in the file name vary. For example, use “a?.zip” (without the quotation marks) to specify aa.zip, ab.zip and so on. •Wildcards (*) let multiple files match the pattern. For example, use “*a.zip” (without the quotation marks) to specify any file that ends with “a.zip”. A file named “testa.zip would match. There could be any number (of any type) of characters in front of the “a.zip” at the end and the file name would still match. A file named “test.zipa” for example would not match. •A * in the middle of a pattern has the Nebula Device check the beginning and end of the file name and ignore the middle. For example, with “abc*.zip”, any file starting with “abc” and ending in “.zip” matches, no matter how many characters are in between. •The whole file name has to match if you do not use a question mark or asterisk. •If you do not use a wildcard, the Nebula Device checks up to the first 80 characters of a file name. |
Sandboxing | Sandboxing provides a safe environment to separate running programs from your network and host devices. Unknown or untrusted programs/codes are uploaded to the Defend Center and executed within an isolated virtual machine (VM) to monitor and analyze the zero-day malware and advanced persistent threats (APTs) that may evade the Nebula Device’s detection, such as anti-malware. Results of cloud sandboxing are sent from the server to the Nebula Device. |
Enabled | Select this option to turn on sandboxing on the Nebula Device |
Log | Enable this option to allow the Security Firewall to create a log when a suspicious file is detected. |
Policy | Specify whether the Nebula Device deletes (Destroy) or forwards (Allow) malicious files. Malicious files are files given a high score for malware characteristics by the Defend Center. |
Inspect selected downloaded files | Select this option to have the Nebula Device hold the downloaded file for up to 2 seconds if the downloaded file has never been inspected before. The Nebula Device will wait for the Defend Center’s result and forward the file in 2 seconds. Sandbox detection may take longer than 2 seconds, so infected files could still possibly be forwarded to the user. ![]() The scan result will be removed from the Nebula Device cache after the Nebula Device restarts. |
File submission options | Specify the type of files to be sent for sandbox inspection. |
Intrusion Detection/Prevention | |
Detection | Select On to enable Detection. |
Prevention | Select On to enable Prevention. |
Label | Description |
VPN Topology | |
VPN Area | Select the name of a VPN area to view on the map. Select Overview to view all VPN areas in this organization on the map. |
Smart VPN | |
VPN Area | Select the name of a VPN to configure. Select + Create VPN area to create a new VPN within the organization. |
![]() | Click the remove icon to delete the VPN area. |
Topology | Click this to select a topology for the VPN area. For details on topologies, see Topology Overview. Select Disable to disable VPN connections for all sites in the VPN area. |
The following settings are shown when Topology is set to Hub-and-Spoke. | |
Branch to Branch VPN | Enable this to allow spoke sites to communicate with each other in the VPN area. When disabled, spoke sites can only communicate with hub sites. |
Spoke | Select one or more sites and then click this to assign the sites as spokes. The sites are added to the spoke list. |
Hub | Select one or more sites and then click this to assign the sites as hubs. The sites are added to the hubs list. |
Security Gateway | Enter the name of a site or Nebula Device to filter the list of sites. |
Hub site | This shows the number of hub site. ![]() |
Spoke site: N | This shows the number of spoke sites (N) in the spoke list. |
# | This shows the priority of the hub site. If the VPN area contains multiple hub sites, then the spoke sites always send traffic through the available hub with the highest priority. You can change the priority of a site by clicking the move icon ( ![]() |
Site | This shows the name of the site in the VPN area. |
Model | This shows the model of the site’s Security Gateway device. |
VPN enable | Click this to enable or disable site-to-site VPN on the site’s Security Gateway. If you disable this setting, the site will leave the VPN area. |
Subnets | This shows the IP subnets of all LAN interfaces behind the site’s Security Gateway. |
NAT traversal | If the Security Gateway is behind a NAT router, enter the public IP address or the domain name that is configured and mapped to the Security Gateway on the NAT router. |
Area communication | Enable this to allow the site to communicate with sites in different VPN areas within the organization. If Topology is set to Site-to-Site, then you must assign at least one site in each VPN area as the Area Leader. The area leaders create VPN tunnels between VPN areas. |
Gateway status | This shows whether the site’s Security Gateway is currently online. |
VPN status | This shows whether the VPN is currently connected. |
WAN status | This shows the IP address of the WAN interface and the public IP address of the site’s Security Gateway. |
Non-Nebula VPN peers | Configure this section to add a non-Nebula gateway, such as an on-premise ZyWALL series device or non-Zyxel gateway, to the VPN area. |
+ Add | Click this button to add a non-Nebula gateway to the VPN area. |
Enabled | Select the check box to enable VPN connections to the non-Nebula gateway. |
Name | Enter the name of the non-Nebula gateway. |
Public IP | Enter the public IP address of the non-Nebula gateway. The public IP address supports both FQDN (Fully Qualified Domain Name) and IP formats. |
Private Subnet | Enter the IP subnet that will be used for VPN connections. The IP range must be reachable from other Nebula Devices in the VPN area. |
IPSec policy | Click to select a pre-defined policy or have a custom one. See Custom IPSec Policy for detailed information. |
Preshared secret | Enter a pre-shared key (password). The Nebula Security Gateway and peer gateway use the key to identify each other when they negotiate the IKE SA. |
Address | Enter the address (physical location) of the Nebula Device. |
Site | Select a site in your organization. By default, all the sites are displayed (Any). |
Device type | Select the type of Nebula Device. By default, all the Nebula Devices are displayed (Any). |
Status | Select the status of the Nebula Device’s firmware. By default, all the status are displayed (Any). Select Good to display the Nebula Devices running a stable firmware with no immediate action is required. Select Warning to display the Nebula Devices with a newer firmware available and immediate action is recommended. The newer firmware may contain security enhancements, new features, and performance improvements. Select Critical to display the Nebula Devices with a newer firmware available and immediate action is required. The existing firmware may have security vulnerabilities and/or lack key performance improvements. Select N/A to display the Nebula Devices that are offline and its firmware status is not available. |
Availability | Select to show the Nebula Devices with Up to date firmware, there is firmware update available for the Nebula Device (Upgrade available), or a specific version of firmware has been installed by Zyxel customer support (Locked). By default, all the available firmware are displayed (Any). |
Upgrade Now | Click this to immediately upgrade the firmware on all selected sites. This button is selectable only when there is firmware update available for the Nebula Devices for the selected sites. |
Schedule Upgrade | Click this to pop-up a window where you can set a specific date and time to upgrade the Nebula Devices firmware on the selected sites. ![]() ![]() |
Reset | Select one or more Site-wide firmware upgrade Schedules, and then click Reset to restore the default site-wide settings (Every Monday at 02:00). Select one or more Per device firmware upgrade Schedules, and then click Reset to allow the Nebula Devices to follow the site-wide firmware management settings. |
Site-wide/Per device | Select your desired filter criteria to filter the list of firmware upgrade schedules. |
Status | This shows the status of the Nebula Device’s firmware. • Green: All Nebula Devices are running Stable or above firmware. • Amber: One or more Nebula Devices is not running the Latest firmware. • Red: One or more Nebula Devices is running firmware that may have security vulnerabilities and/or lack key performance improvements. • Gray: No schedule is set for upgrading the Nebula Device’s firmware. |
Site | This shows which site the Nebula Device is in. Click the site name to go to the site’s Dashboard. |
Device type | This shows the type of Nebula Device. |
Schedule | This shows the day and time when a new firmware upgrade is scheduled to occur. Site-wide settings means the Nebula Device is following the site-wide firmware schedule. Per device settings means a firmware schedule is set for the Nebula Device and it will not follow the site-wide firmware schedule. |
# of devices | This shows the number of Nebula Devices in the site for a particular Schedule status. Click this to change the schedule (see the Schedule upgrade field in Organization-Wide > Configure > Firmware management > Devices for more information). |
Availability | This shows whether the firmware on the Nebula Device is Up to date, there is firmware update available for the Nebula Device (Upgrade available), or a specific version of firmware has been installed by Zyxel customer support (Locked). |
![]() | Click this icon to show and hide columns in the table. |
Site/Status/Device type/Tag/Model/Current version/Firmware status/Firmware type/Availability/Locked | Specify your desired filter criteria to filter the list of Nebula Devices. |
Upgrade Now | Click this to immediately install the firmware on the selected Nebula Devices. This button is selectable only when there is firmware update available for the selected Nebula Devices. |
Schedule upgrade | Click this to pop up a window where you can create a new schedule for the selected Nebula Devices. You can select to upgrade firmware according to the organization-wide schedule configured for the Nebula Device type in the site, create a recurring schedule, edit the schedule with a specific date and time when firmware update is available for all the selected Nebula Devices, or immediately install the firmware. With a recurring schedule, the NCC will check and perform a firmware update when a new firmware release is available for any of the selected Nebula Devices. If the NCC service is downgraded from Nebula Professional Pack to Nebula Base, the Nebula Devices automatically changes to adhere to the organization-wide schedule. |
Reset | Select one or more Nebula Devices, and then click Reset to allow the Nebula Devices to follow the site-wide firmware management settings. |
Status | This shows the status of the Nebula Device. • Green: The Nebula Device is online and has no alerts. • Amber: The Nebula Device has alerts. • Red: The Nebula Device is offline. • Gray: The Nebula Device has been offline for 7 days or more. |
Device type | This shows the type of the Nebula Device. |
Model | This shows the model number of the Nebula Device. |
Tag | This shows the tag created and added to the Nebula Device. |
Name | This shows the descriptive name of the Nebula Device. |
MAC address | This shows the MAC address of the Nebula Device. |
S/N | This shows the serial number of the Nebula Device. |
Site | This shows the descriptive name of the site. |
Current version | This shows the version number of the firmware the Nebula Device is currently running. It shows N/A when the Nebula Device goes offline and its firmware version is not available. |
Firmware status | The status shows Good if the Nebula Device is running a stable firmware and no immediate action is required. See the description of a stable firmware on the next field Firmware type. The status shows Warning if a newer firmware is available and immediate action is recommended. The newer firmware may contain security enhancements, new features, and performance improvements. The status shows Critical if a newer firmware is available and immediate action is required. The firmware may have security vulnerabilities and/or lack key performance improvements. The status shows Custom if the Nebula Device is running a firmware with specialized features that is not available to the general public. The status changes to Upgrading... after you click Upgrade Now to install the firmware immediately. |
Firmware type | This shows Stable when the installed firmware may not have the latest features but has passed Zyxel internal and external testing. This shows Latest when the installed firmware is the most recent release with the latest features, improvements, and bug fixes. This shows General Availability when the installed firmware is a release before Latest, but is still undergoing Zyxel external testing. This shows Dedicated when the installed firmware is locked and Zyxel support is monitoring. Contact Zyxel customer support if you want to unlock the firmware in order to upgrade to a later one. This shows Beta when the installed firmware is a release version for testing the latest features and is still undergoing Zyxel internal and external testing. This shows N/A when the Nebula Device is offline and its firmware status is not available. ![]() |
Upgrade scheduled | This shows the date and time when a new firmware upgrade is scheduled to occur. Otherwise, it shows Follow upgrade time and the Nebula Device sticks to the site-wide schedule or No when the firmware on the Nebula Device is up-to-date or the Nebula Device goes offline and its firmware status is not available. A lock icon displays if a specific schedule is created for the Nebula Device, which means the Nebula Device firmware will not be upgraded according to the schedule configured for all Nebula Devices in the site. |
Last upgrade time | This shows the last date and time the firmware was upgraded on the Nebula Device. |
Schedule upgrade version | This shows the version number of the firmware which is scheduled to be installed. |
![]() | Click this icon to display a greater or lesser number of configuration fields. |
version number timeline | firmware type | version number timeline | firmware type |
V6 | Latest | V5 | General Availability |
V7 | Latest | V6 | General Availability |
