Organization-wide Manage
Use the Organization-wide manage menus to create new sites, register or unregister a Nebula Device, change organization general settings, and manage licenses, user accounts, administrator accounts or VPN members in the organization.
Organization Portal
This screen shows you the site locations on a Google map and the summary of sites, site tags and connected Nebula Devices for the selected organization.
*The Nebula Accessories will not display on Google map.
Click Organization-wide > Organization-wide manage > Organization portal to access this screen.
Sites
Click the Sites tab in the Overview screen to view detailed information of the sites which are associated with the selected organization.
Organization-wide > Organization-wide manage > Organization portal: Sites
Label
Description
Tag
Select one or multiple sites and click this button to create a new tag for the sites or delete an existing tag.
Delete
Select the sites and click this button to remove it.
Search
Enter a key word as the filter criteria to filter the list of sites.
Sites
This shows the number of sites in this organization.
Over the last day
This shows how many clients are associated with the sites in this organization and the total amount of data transmitted or received by the clients in the past day.
Export
Click this button to save the site list as a CSV or XML file to your computer.
Status
This shows the status of Nebula Devices in the site.
• Green: All Nebula Devices are online and have no alerts.
• Amber: Some Nebula Devices have alerts.
• Red: Some Nebula Devices are offline.
• Gray: All Nebula Devices have been offline for 7 days or more.
• White: No Nebula Devices.
Name
This shows the descriptive name of the site.
Usage
This shows the amount of data consumed by the site.
*This shows ‘–’ for Nebula Accessories.
Clients
This shows the number of clients connected to Nebula Devices in the site.
Tag
This shows the user-specified tag that is added to the site.
Site health
This shows the percentage of uptime in a given time interval to indicate the site’s network availability.
• Green: 95 – 100% network uptime
• Dark green: 75 – 95% network uptime
• Brown: 50 – 75% network uptime
• Red: < 50% network uptime
• Grey: No uptime data
Device
This shows the total number of Nebula Devices deployed in the site.
Offline device
This shows the number of Nebula Devices which are added to the site but not accessible by the NCC now.
% Offline
This shows what percentage of the connected clients are currently offline.
Click this icon to display a greater or lesser number of configuration fields.
Site tags
Click the Site tags tab in the Overview screen to view the tags created and added to the sites for monitoring or management purposes.
Organization-wide > Organization-wide manage > Organization portal: Site tags
Label
Description
Search
Enter a key word as the filter criteria to filter the list of tags.
Site tags
This shows the number of site tags created and added to the sites in this organization.
Over the last day
This shows the number of clients associated with the sites in this organization and the total amount of data transmitted or received by the clients in the past day.
Export
Click this button to save the tag list as a CSV or XML file to your computer.
Status
This shows the status of Nebula Devices in sites with the specified tag.
Tag
This shows the name of the specified tag.
Site
This shows the total number of sites with the specified tag.
Offline device
This shows the number of offline Nebula Devices in all sites with the specified tag.
Clients
This shows the number of clients in sites with the specified tag.
Usage
This shows the total amount of data consumed in all sites with the specified tag.
Device
This shows the total number of Nebula Devices deployed to all sites with the specified tag.
Offline site
This shows the number of offline sites with the specified tag.
% Offline
This shows what percentage of all sites with the specified tag are currently offline.
Devices
Click the Devices tab in the Organization portal screen to view the detailed information about Nebula Devices which are connected to the sites in the selected organization.
Organization-wide > Organization-wide manage > Organization portal: Devices
Label
Description
Search
Enter a key word as the filter criteria to filter the list of connected Nebula Devices.
Devices
This shows the number of Nebula Devices assigned to the sites in this organization.
Over the last day
Export
Click this button to save the Nebula Device list as a CSV or XML file to your computer.
Status
This shows the status of the Nebula Device.
• Green: The Nebula Device is online.
• Amber: The Nebula Device recently had alerts.
• Red: The Nebula Device was recently offline.
• Gray: The Nebula Device has been offline for more than 6 days.
Model
This shows the model number of the Nebula Device.
Name
This shows the descriptive name of the Nebula Device.
Site
This shows the name of the site to which the Nebula Device is connected.
MAC address
This shows the MAC address of the Nebula Device.
Tag
This shows the user-specified tag for the Nebula Device.
Clients
This shows the number of the clients which are currently connected to the Nebula Device.
*This shows ‘–’ for Accessories.
Usage
This shows the amount of data consumed by the Nebula Device.
Serial number
This shows the serial number of the Nebula Device.
Configuration status
This shows whether the configuration on the Nebula Device is up-to-date.
Connectivity
This shows the Nebula Device connection status.
The red time slot indicates the connection to the NCC is down, and the green time slot indicates the connection is up. Move the cursor over a time slot to see the actual date and time when a Nebula Device is connected or disconnected.
Public IP
This shows the global (WAN) IP address of the Nebula Device.
Configuration Management
Configuration synchronization allows you to easily copy configurations from one site or Nebula Device to another. Use this screen to synchronize the configuration between sites or switch ports. You can also back up the current configurations for sites or switches to the NCC and restore the configuration at a later date.
Click Organization-wide > Organization-wide manage > Configuration management to access this screen.
Label
Description
Synchronization
Settings
Specify whether general site configuration or just SSID settings of a site will be propagated to other sites. Click What will be synchronized? to view detailed information.
From source site
Select the site from which you want to copy its site configuration to other sites.
To Site(s)
Select one or more sites to which you want to import the copied site configuration. You can also select the site tags created using the Organization-wide > Organization-wide manage > Organization portal: Sites screen.
Sync
Click this button to start synchronizing configuration settings between the selected sites.
Switch settings clone
From source device
Select the Nebula Switch from which you want to copy its Switch port settings to other Nebula Devices.
To device(s)
Select one or more Nebula Switches to which you want to import the copied Switch port settings.
*Only Nebula Switches of the same model can synchronize. Both Switches should be registered to a site in the organization.
Clone
Click this button to start synchronizing Switch port settings between the selected Nebula Devices.
Backup & Restore
*To back up or restore a previously saved configuration, your administrator account should have full access to the organization.
*The Security Firewall(s) in Cloud Monitoring mode cannot use the back up or restore function.
Site(s) settings
You can create up to three site configuration backups for the organization.
The NCC automatically creates and saves one backup when you perform configuration restoration. The automatic backup cannot be deleted.
Backup
This shows the index number of the site configuration backup.
Description
This shows the descriptive name of the backup.
*When you click Add to create a new backup, you need to enter a name for the backup in order to save it to the NCC.
Date (UTC)
This shows the date and time the backup was saved on the NCC server.
Admin
This shows the name of the administrator account who performed the backup.
Remove
Click the remove icon to delete the backup.
Add
Click this button to create a new configuration backup of all the sites in the organization.
Restore from backup
Select the backup you want to restore.
Restore to site(s)
Select one or more sites to which you want to restore the specified configuration backup.
Restore
Click this button to overwrite the settings of the sites with the selected configuration backup.
Switch settings
At the time of writing, only one backup is allowed per Nebula Device.
Backup
This shows the index number of the Switch configuration backup.
Switch
This shows the name of the Switch.
Description
Model
This shows the model number of the Switch.
Date (UTC)
Admin
Remove
Add
Click this button to create a new configuration backup of a specific Switch.
This button is selectable only when you have at least one Switch in the organization.
Restore from backup
Restore to device(s)
Select one or more Nebula Switches to which you want to restore the specified configuration backup.
*You can restore the backup to the same Switch or Switches of the same model and registered to a site in the organization.
Restore
Click this button to overwrite the settings of the Switches with the selected configuration backup.
Configuration Templates
A configuration template is a virtual site. The settings you configured in a template will apply to the real sites which are bound to the template. If you do not want to apply any new settings from the template to a site, just unbind that site. If you want to configure some specific settings directly in a site after the site is bound to a template, turn on the local override function (see Local Override).
Use this screen to create and manage configuration templates. You can then bind or unbind a site from the template (see Site Binding).
*A site can only be bound to one template. The same template can be used by multiple sites. The sites and the template should belong to the same organization for binding.
*If the NCC service is downgraded from Nebula Professional Pack to Nebula Base, all the sites will be unbound from the templates but retain the settings already applied from the template.
*The settings from the Configuration templates will not apply to Security Firewall(s) in Cloud Monitoring mode.
Click Organization-wide > Organization-wide manage > Configuration templates to access this screen.
Label
Description
Create
Click this button to create a new configuration template. You can copy settings from an existing site or configuration template, or have a new template with default settings. It is optional to bind one or more sites to the template when you are creating a template.
Delete
Click this button to remove the selected templates. A window pops up asking you to confirm that you want to delete the templates.
If you remove a template that is being used by a site, the site will be unbound from the template automatically and retain the settings previously applied from the template.
Search
Enter a key word as the filter criteria to filter the list of templates.
Templates
This shows how many templates match the filter criteria and how many templates are created in total.
Name
This shows the name of the template.
# Bound sites
This shows the number of the sites bound to the template.
Bound sites
This shows the name of the sites bound to the template.
Site Binding
Use this screen to bind or unbind a site from a template. Click an existing template from the list in the Organization-wide > Organization-wide manage > Configuration templates screen to access this screen. To go back to the previous screen, click the Configuration templates list link.
Organization-wide > Organization-wide manage > Configuration templates: Template
Label
Description
Bind additional site
Click this button to bind more sites to the template. A window displays. Select the name of the sites in the Target sites field and click Bind.
Unbind
Click this button to remove the selected sites from the template. The site which is unbound from the template still retains the settings applied from the template.
Search
Sites
This shows how many sites match the filter criteria and how many sites are bound to the template in total.
Name
This shows the name of the site bound to the template.
Tag
This shows the tags added to the site.
Device
This shows the number of Nebula Devices which are assigned to the site.
Local override
This shows which settings in the template do not apply to the site.
Template settings
An administrator that has full access to the organization can modify the template configurations. To access a template’s configuration screen, select the template name from the Site field in the NCC title bar. It also shows the number of sites that are bound to the template on each configuration screen.
*At the time of writing, you can use a template to configure site-wide, Switches, and access points settings.
Local Override
When a site is bound to a template, you can see the name of the template on the site’s configuration screens (which are also available in a template and can be configured).
There is also an option to make the changes you made locally to a site persist. If you select the override checkbox of the site’s configuration screen, all the configuration screens under the same menu tab (Site-Wide or Switches) are configurable. Settings in these screens will not be affected and modified by the template. If the override checkbox is not selected, any changes of the same configuration screen in the template apply to the site.
Switch Port Profile and Configuration
Just as a configuration template is a virtual site, so is a profile to a Switch. The settings you configured in a profile will apply to the Switches which are bound to the profile. If you do not want to apply any new settings from the profile to a Switch, just unbind that Switch. If you want to configure some specific settings directly in a Switch (For example, a port’s Broadcast (pps) value. See Update ports for details.) after the Switch is bound to a profile, turn on the local override function (see Local Override).
VPN Orchestrator
VPN Orchestrator enables you to automatically create Virtual Private Network (VPN) connections between sites within an organization. This allows the Security Gateway of each site and the Nebula Devices behind it to communicate securely.
*You can manually create VPN connections between sites at Site-wide > Configure > Security Gateway > Site-to-Site VPN or Site-wide > Configure > Firewall > Site-to-Site VPN.
Topology Overview
There are two topologies you can use when creating a site-to-site VPN.
• Fully Meshed: In a fully-meshed VPN topology (1 in the figure below), there is a VPN connection between every two sites in the organization. Sites can communicate directly with each other, but having permanent tunnels between every site takes up more resources.
• Hub-and-spoke: In a hub-and-spoke topology (2 in the figure below), every site is either a hub or a spoke. There is a VPN connection between each spoke site (B, C, D, and E) and the hub site (A). Traffic from each spoke site must first go through the hub site. If the hub site fails, the site-to-site VPN network fails. To avoid this, you can assign more than one hub site.
VPN Topologies (Fully Meshed and Hub-and-Spoke)
VPN Areas
An organization can contain multiple VPN areas. Each VPN area is an independent VPN with its own sites, settings, and topology. Every organization has a default VPN area called Default, which cannot be deleted. Sites in different VPN areas within the same organization can communicate if you enable the Area communication setting.
VPN Orchestrator Screen
Use this screen to manage and create site-to-site VPNs within the current organization. Click Organization-wide > Organization-wide manage > VPN orchestrator to access this screen.
*The Security Firewall(s) in Cloud Monitoring mode will not show on the list and map.
Label
Description
VPN Topology
VPN Area
Select the name of a VPN area to view on the map.
Select Overview to view all VPN areas in this organization on the map.
VPN Member
VPN Area
Select the name of a VPN to configure.
Select + Create VPN area to create a new VPN within the organization.
Click the remove icon to delete the VPN area.
Topology
Click this to select a topology for the VPN area. For details on topologies, see Topology Overview.
Select Disable to disable VPN connections for all sites in the VPN area.
The following settings are shown when Topology is set to Hub-and-Spoke.
Branch to Branch VPN
Enable this to allow spoke sites to communicate with each other in the VPN area. When disabled, spoke sites can only communicate with hub sites.
Spoke
Select one or more sites and then click this to assign the sites as spokes. The sites are added to the spoke list.
Hub
Select one or more sites and then click this to assign the sites as hubs. The sites are added to the hubs list.
Security Gateway
Enter the name of a site or Nebula Device to filter the list of sites.
Hub site
This shows the number of hub site.
*Only one hub site is supported.
Spoke site: N
This shows the number of spoke sites (N) in the spoke list.
This shows the priority of the hub site. If the VPN area contains multiple hub sites, then the spoke sites always send traffic through the available hub with the highest priority.
You can change the priority of a site by clicking the move icon (), and then dragging the site up or down in the list.
Site
This shows the name of the site in the VPN area. Click the name to go to the site’s VPN configuration page (Site-wide > Configure > Firewall > Site-to-Site VPN).
Model
This shows the model of the site’s Security Appliance device.
VPN enable
Click this to enable (join) or disable (leave) site-to-site VPN on the site’s Security Appliance.
If you disable this setting, the site will leave the VPN area.
Subnets
This shows the IP subnets of all LAN interfaces behind the site’s Security Appliance.
NAT traversal
If the Security Appliance is behind a NAT router, enter the public IP address or the domain name that is configured and mapped to the Security Appliance on the NAT router.
Area communication
Enable this to allow the site to communicate with sites in different VPN areas within the organization.
If Topology is set to Site-to-Site, then you must assign at least one site in each VPN area as the Area Leader. The area leaders create VPN tunnels between VPN areas.
Gateway status
This shows whether the site’s Security Appliance is currently online.
VPN status
This shows whether the VPN is currently connected.
WAN status
This shows the IP address of the WAN interface and the public IP address of the site’s Security Appliance.
Non-Nebula VPN peers
Configure this section to add a non-Nebula gateway, such as an on-premise ZyWALL series device or non-Zyxel gateway, to the VPN area.
+ Add
Click this button to add a non-Nebula gateway to the VPN area.
Enabled
Select the checkbox to enable VPN connections to the non-Nebula gateway.
Name
Enter the name of the non-Nebula gateway.
Public IP
Enter the public IP address of the non-Nebula gateway. The public IP address supports both FQDN (Fully Qualified Domain Name) and IP formats.
Private Subnet
Enter the IP subnet that will be used for VPN connections. The IP range must be reachable from other Nebula Devices in the VPN area.
IPSec policy
Click to select a pre-defined policy or have a custom one. See Custom IPSec Policy for detailed information.
Pre-shared secret
Enter a pre-shared key (password). The Nebula Security Appliance and peer gateway use the key to identify each other when they negotiate the IKE SA.
Address (physical location)
Enter the address (physical location) of the remote device. You can find this on the VPN Topology section on this screen.
Click the remove icon to delete the entry.
Security Profile Sync
Security profile sync allows you to share the same Security Firewall device security service settings with multiple sites in an organization. This replaces the Unified Threat Management (UTM) settings configured for each site at Site-wide > Configure > Firewall > Security service.
Configuring Security Profile Sync
Follow the steps below to enable security profile sync in an organization.
1 Go to Organization-wide > Organization-wide manage > Security profile sync. Select Enabled, and then under Sync sites add the sites that you want to share security settings.
*You can only add sites that have a Security Firewall device.
2 Configure security service settings for Content Filter, Application Patrol, DNS/URL Threat Filter, IP Reputation, Anti-Malware, Sandboxing, and Intrusion Prevention System (IPS). Then click Save.
All security settings are synced to the selected sites.
3 If you change the settings in the Security profile sync screen, the changes will be copied to all selected sites.
4 If you want to modify security settings for an individual site, go to Site-wide > Configure > Firewall > Security service and select Override security profile sync.
Security Profile Sync Screen
Use this screen to enable and configure security profile sync. Click Organization-wide > Organization-wide manage > Security profile sync to access this screen.
Organization-wide > Organization-wide manage > Security Profile Sync
Label
Description
Enabled
Click this to enable or disable security profile sync for the organization.
Sync sites
Select one or more sites that you want to apply the following security settings configured on this screen:
• Content Filter
• Application Patrol
• DNS/URL Threat Filter
• IP Reputation
• Anti-Malware
• Sandboxing
• Intrusion Prevention System (IPS)
• External block list (for IP Reputation and DNS/URL Threat Filter)
Alternatively, select All sites to apply the security settings to all sites in the organization.
Content Filter
Drop connection when there is an HTTPS connection with SSL v3 (or previous version)
Select On to have the Nebula Security Firewall block HTTPS web pages using SSL V3 or a previous version.
Denied Access Message
Enter a message to be displayed when content filter blocks access to a web page. Use up to 127 characters (0–9a–zA–Z;/?:@&=+$\.–_!~*'()%,”). For example, “Access to this web page is not allowed. Please contact the network administrator”.
It is also possible to leave this field blank if you have a URL specified in the Redirect URL field. In this case if the content filter blocks access to a web page, the Nebula Security Firewall just opens the web page you specified without showing a denied access message.
Redirect URL
Enter the URL of the web page to which you want to send users when their web access is blocked by content filter. The web page you specify here opens in a new frame below the denied access message.
Use “http://” or “https://” followed by up to 262 characters (0–9a–zA–Z;/?:@&=+$\.-_!~*'()%). For example, http://192.168.1.17/blocked access.
Enabled
Select the checkbox to enable the content filter profile.
Description
Enter a description for this profile.
Click this icon to change the profile settings.
Click this icon to remove the profile.
Add
Click this to create a content filter profile. See Create a Content Filter Profile for more information.
Application Patrol
Application profiles
Name
Enter a name for this profile for identification purposes.
Description
Add
Click this icon to create an application patrol profile. See Add Application Patrol Profile for more information.
Log
Select whether to have the Nebula Device generate a log (log), log and alert (log alert) or not (no) when the policy is matched to the criteria listed above.
DNS Threat Filter
Select On to turn on the rule. Otherwise, select Off to turn off the rule.
DNS Threat Filter policy
Select Pass to have the Nebula Device allow the DNS query packet and not reply with a DNS reply packet containing a default or custom-defined IP address.
Select Redirect to have the Nebula Device reply with a DNS reply packet containing a default or custom-defined IP address.
DNS Threat Filter Redirect IP
Enter the IP address to have the Nebula Device reply with a DNS reply packet containing a default or custom-defined IP address when a DNS query packet contains an FQDN with a bad reputation. The default IP is the dnsft.cloud.zyxel.com IP address. If you select a custom-defined IP, then enter a valid IPv4 address in the text box.
URL Threat Filter
URL Threat Filter Policy
Select Pass to allow users to access web pages that the external web filtering service has not categorized.
Select Block to prevent users from accessing web pages that the external web filtering service has not categorized. When the external database content filter blocks access to a web page, it displays the denied access message that you configured in the Content Filter General screen along with the category of the blocked web page.
Select Warn to display a warning message before allowing users to access web pages that the external web filtering service has not categorized.
URL Threat Filter Denied Access Message
Enter a message to be displayed when content filter blocks access to a web page. Use up to 127 characters (0–9a–zA–Z;/?:@&=+$\.-_!~*'()%,”). For example, “Access to this web page is not allowed. Please contact the network administrator”.
It is also possible to leave this field blank if you have a URL specified in the Redirect URL field. In this case if the content filter blocks access to a web page, the Nebula Device just opens the web page you specified without showing a denied access message.
URL Threat Filter Redirect URL
Test Threat Category
Enter a URL using http://domain or https://domain and click the Test button to check if the domain belongs to a URL threat category.
Category List
These are categories of web pages based on their content. Select categories in this section to control access to specific types of Internet content.
Block list
Sites that you want to block access to, regardless of their content rating, can be blocked by adding them to this list.
Enter host names such as www.bad-site.com into this text field. Do not enter the complete URL of the site – that is, do not include “http://”. All sub-domains are also blocked. For example, entering “bad-site.com” also blocks “www.badsite.com”, “partner.bad-site.com”, “press.bad-site.com”, and so on. You can also enter just a top level domain. For example, enter .com to block all .com domains.
Use up to 127 characters (0–9 a–z). The casing does not matter.
Allow list
Sites that you want to allow access to, regardless of their content rating, can be allowed by adding them to this list.
Enter host names such as www.good-site.com into this text field. Do not enter the complete URL of the site – that is, do not include “http://”. All sub-domains are allowed. For example, entering “zyxel.com” also allows “www.zyxel.com”, “partner.zyxel.com”, “press.zyxel.com”, and so on. You can also enter just a top level domain. For example, enter .com to allow all .com domains.
IP Reputation
Enabled
Select this option to turn on IP blocking on the Nebula Device.
Log
Select this option to create a log on the Nebula Device when the packet comes from an IPv4 address with bad reputation.
Policy
Select Pass to have the Nebula Device allow the packet to go through.
Select Block to have the Nebula Device deny the packets and send a TCP RST to both the sender and receiver when a packet comes from an IPv4 address with bad reputation.
Threat level threshold
Select the threshold threat level to which the Nebula Device will take action (High, Medium and above, Low and above).
The threat level is determined by the IP reputation engine. It grades IPv4 addresses.
• High: an IPv4 address that scores 0 to 20 points.
• Medium and above: an IPv4 address that scores 0 to 60 points.
• Low and above: an IPv4 address that scores 0 to 80 points.
For example, a score of “10” will cause the Nebula Device to take action whether you set the Threat level threshold at High, Medium and above, or Low and above.
But a score of “61” will not cause the Nebula Device to take any action if you set the Threat level threshold at Medium and above.
Test Category
Enter an IPv4 address of a website, and click the Test button to check if the website associates with suspicious activities that could pose a security threat to users or their computers.
Category list
Select the categories of packets that come from the Internet and are known to pose a security threat to users or their computers.
Block list
Add the IPv4 addresses that the Nebula Device will block the incoming packets.
Allow list
Add the IPv4 addresses that the Nebula Device will allow the incoming packets.
Anti-Malware
Enabled
Log
Select whether to have the Nebula Device generate a log when the policy is matched to the criteria listed above.
Scan mode
Express mode
In this mode you can define which types of files are scanned using the File Type For Scan fields. The Nebula Device then scans files by sending each file’s hash value to a cloud database using cloud query. This is the fastest scan mode.
Stream mode
In this mode the Nebula Device scans all files for viruses using its anti-malware signatures to detect known virus pattens. This is the deepest scan mode.
Hybrid mode
In this mode you can define which types of files are scanned using the File Type For Scan fields. The Nebula Device then scans files by sending each file’s hash value to a cloud database using cloud query. It also scans files using anti-malware signatures, and Threat Intelligence Machine Learning. This mode combines Express Mode and Stream Mode to offer a balance of speed and security.
Cloud Query
Select the Cloud Query supported file types for the Nebula Device to scan for viruses.
Block list
This field displays the file or encryption pattern of the entry. Enter a file pattern that would cause the Nebula Device to log and modify this file.
•Use up to 80 characters. Alphanumeric characters, underscores (_), dashes (-), question marks (?) and asterisks (*) are allowed.
•A question mark (?) lets a single character in the file name vary. For example, use “a?.zip” (without the quotation marks) to specify aa.zip, ab.zip and so on.
•Wildcards (*) let multiple files match the pattern. For example, use “*a.zip” (without the quotation marks) to specify any file that ends with “a.zip”. A file named “testa.zip would match. There could be any number (of any type) of characters in front of the “a.zip” at the end and the file name would still match. A file named “test.zipa” for example would not match.
•A * in the middle of a pattern has the Nebula Device check the beginning and end of the file name and ignore the middle. For example, with “abc*.zip”, any file starting with “abc” and ending in “.zip” matches, no matter how many characters are in between.
•The whole file name has to match if you do not use a question mark or asterisk.
•If you do not use a wildcard, the Nebula Device checks up to the first 80 characters of a file name.
Allow list
Enter the file or encryption pattern for this entry. Specify a pattern to identify the names of files that the Nebula Device should not scan for viruses.
Sandboxing
Sandboxing provides a safe environment to separate running programs from your network and host devices. Unknown or untrusted programs/codes are uploaded to the Defend Center and executed within an isolated virtual machine (VM) to monitor and analyze the zero-day malware and advanced persistent threats (APTs) that may evade the Nebula Device’s detection, such as anti-malware. Results of cloud sandboxing are sent from the server to the Nebula Device.
Enabled
Select this option to turn on sandboxing on the Nebula Device
Log
Enable this option to allow the Security Firewall to create a log when a suspicious file is detected.
Policy
Specify whether the Nebula Device deletes (Destroy) or forwards (Allow) malicious files. Malicious files are files given a high score for malware characteristics by the Defend Center.
Inspect selected downloaded files
Select this option to have the Nebula Device hold the downloaded file for up to 2 seconds if the downloaded file has never been inspected before. The Nebula Device will wait for the Defend Center’s result and forward the file in 2 seconds. Sandbox detection may take longer than 2 seconds, so infected files could still possibly be forwarded to the user.
*The Nebula Device only checks the file types you selected for sandbox inspection.
The scan result will be removed from the Nebula Device cache after the Nebula Device restarts.
File Types to Scan
Specify the type of files to be sent for sandbox inspection.
Enabled
Select this to activate the IPS feature which detects and prevents malicious or suspicious packets and responds instantaneously.
Mode
Select Detection to have the Nebula Device only create a log message when a stream of data matches a malicious signature. Alternatively, select Prevention to have the Nebula Device perform a user-specified action when a stream of data matches a malicious signature.
External Block List
IP Reputation (EBL)
Select this to have the Nebula Device block the incoming packets that come from the listed addresses in the block list file on the server.
External block list
Enabled
Select this to turn on the rule.
Name
Enter an identifying name for the block list file. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long.
External DB
Enter the exact file name, path and IP address of the server containing the block list file. The file type must be ‘txt’.
For example, http://172.16.107.20/blacklist-files/myip-ebl.txt
The server must be reachable from the Nebula Device.
Description
Enter a description of the block list file. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long.
Click this icon to remove the entry.
Add
Click this button to create a new IP reputation external block list profile entry.
Schedule update
The signatures for DNS Filter and URL Threat Filter are the same. These signatures are continually updated as new malware evolves. New signatures can be downloaded to the Nebula Device periodically if you have subscribed for the URL Threat filter signatures service.
You need to create an account at Zyxel, register your Nebula Device and then subscribe for URL Threat filter service in order to be able to download new signatures from Zyxel.
Select External DB schedule update and Daily to set the time of the day, or Weekly to set the day of the week and the time of the day.
Schedule signature updates for a day and time when your network is least busy to minimize disruption to your network.
DNS/URL Threat Filter (EBL)
Select this to have the Nebula Device automatically block packets that come from the listed addresses in the block list file on the server.
External block list
Enabled
Name
Enter the identifying name for the block list file. You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 60 characters long.
External DB
Enter the file name, path and IP address of the server containing the block list file. For example, http://172.16.107.20/blacklist-files/myip-ebl.txt
Description
Add
Click this button to create a new DNS/URL threat filter external block list entry.
Schedule update
New IP reputation signatures can be downloaded to the Nebula Device periodically if you have subscribed for the IP reputation signatures service.You need to create an account at Zyxel, register your Nebula Device and then subscribe for IP reputation service in order to be able to download new signatures from Zyxel.
Firmware Management
Use this screen to upgrade Nebula Device firmware, or schedule a firmware upgrade for Nebula Devices within the sites in the organization. Click Organization-wide > Organization-wide manage > Firmware management to access this screen.
Firmware Management Overview Screen
Use this screen to view and/or schedule a firmware upgrade for Nebula Devices within each site in the organization. You can make different schedules for different sites in the organization. Click Organization-wide > Organization-wide manage > Firmware management > Overview to access this screen.
You can select Nebula Devices by device type and by site, but you cannot select individual Nebula Devices. For example, you can upgrade all Switches in Site A and all APs in Site B. To upgrade individual Nebula Devices, go to Organization-wide > Organization-wide manage > Firmware management > Devices.
*This is a Nebula Professional Pack feature. If your Nebula Professional Pack license expires, scheduled firmware upgrades will still run.
Firmware Upgrade Priority
NCC prioritizes the different Nebula Device firmware upgrade schedules as follows, from highest to lowest as follows:
1. Individual Nebula Device upgrade schedule (set at MSP > MSP cross-org manage > Firmware upgrades > Schedule upgrades).
2. Individual Nebula Device upgrade schedule (set at Organization-wide > Organization-wide manage > Firmware management > Devices).
3. Organization-wide or site-wide upgrade schedule. If both are set, the schedule that was most recently set takes priority.
4. NCC default per-device upgrade schedule and default site-wide upgrade schedule (14 days after new firmware is released).
Label
Description
Site
You can set the filter to display specific Nebula Devices in a site in your organization. By default, all the sites are displayed (Any).
Device type
Select the type of Nebula Device. By default, all the Nebula Devices are displayed (Any).
Status
Select the Nebula Devices by their firmware status. By default, all Nebula Devices are displayed (Any).
Select Good to display the Nebula Devices running a stable firmware and no immediate action is required.
Select Warning to display the Nebula Devices with a newer firmware available and immediate action is recommended. The newer firmware may contain security enhancements, new features, and performance improvements.
Select Critical to display the Nebula Devices with a newer firmware available and immediate action is required. The existing firmware may have security vulnerabilities and/or lack key performance improvements.
Select N/A to display the Nebula Devices that are offline and its firmware status is not available.
Availability
Select to show the Nebula Devices with Up to date firmware, or with firmware update available for the Nebula Device (Upgrade available), or with a specific version of firmware has been installed by Zyxel customer support (Locked). By default, all available firmware is displayed (Any).
Upgrade Now
Click this to immediately upgrade the firmware on all selected sites.
This button is selectable only when there is firmware update available for the Nebula Devices for the selected sites.
Schedule Upgrade
Click this to pop-up a window where you can set a specific date and time to upgrade the Nebula Devices firmware on the selected sites.
*Nebula Devices are upgraded according to the time zone of the site they are in.
Reset
Select one or more Site-wide firmware upgrade Schedules, and then click Reset to restore the default site-wide settings (Every Monday at 02:00).
Select one or more Per device firmware upgrade Schedules, and then click Reset to allow the Nebula Devices to follow the site-wide firmware management settings.
Site-wide/Per device /Both
Select your desired filter criteria to filter the list of firmware upgrade schedules.
*Drag the following column headings to change the order. Click the column heading to change the sorting, ascending or descending order.
Status
This shows the status of the Nebula Device’s firmware.
• Green: All Nebula Devices are running Stable or above firmware.
• Amber: One or more Nebula Devices is not running the Latest firmware.
• Red: One or more Nebula Devices is running firmware that may have security vulnerabilities and/or lack key performance improvements.
• Gray: No schedule is set for upgrading the Nebula Device’s firmware.
Site
This shows which site the Nebula Device is in.
Click the site name to go to the site’s Dashboard.
Device type
This shows the type of Nebula Device.
Schedule
This shows the day and time when a new firmware upgrade is scheduled to occur. Site-wide settings means the Nebula Device is following the site-wide firmware schedule. Per device settings means a firmware schedule is set for the Nebula Device and it will not follow the site-wide firmware schedule.
# of devices
This shows the number of Nebula Devices in the site for a particular Schedule status. Click this to change the schedule (see the Schedule upgrade field in Organization-wide > Organization-wide manage > Firmware management > Devices for more information).
Availability
This shows whether the firmware on the Nebula Device is Up to date, there is firmware update available for the Nebula Device (Upgrade available), or a specific version of firmware has been installed by Zyxel customer support (Locked).
Click this icon to show and hide columns in the table.
Firmware Management Devices Screen
Use this screen to make different firmware upgrade schedules for the Nebula Devices in the organization. Click Organization-wide > Organization-wide manage > Firmware management > Devices to access this screen.
*While installing a firmware update, the Nebula Device will continue to operate normally until it reboots. The reboot will take 3 to 5 minutes, so it is best to pick an upgrade time that has minimal impact on your network.
Label
Description
Site/Status/Device type/Tag/Model/Current version/Firmware status/Firmware type/Availability/Locked
Specify your desired filter criteria to filter the list of Nebula Devices.
Upgrade Now
Click this to immediately install the firmware on the selected Nebula Devices.
This button is selectable only when there is firmware update available for the selected Nebula Devices.
Schedule upgrade
Click this to pop up a window where you can create a new schedule for the selected Nebula Devices.
You can select to upgrade firmware according to the organization-wide schedule configured for the Nebula Device type in the site, create a recurring schedule, edit the schedule with a specific date and time when firmware update is available for all the selected Nebula Devices, or immediately install the firmware.
With a recurring schedule, the NCC will check and perform a firmware update when a new firmware release is available for any of the selected Nebula Devices. If the NCC service is downgraded from Nebula Professional Pack to Nebula Base, the Nebula Devices automatically changes to adhere to the organization-wide schedule.
Reset
Select one or more Nebula Devices, and then click Reset to allow the Nebula Devices to follow the site-wide firmware management settings.
Status
• Green: The Nebula Device is online and has no alerts.
• Amber: The Nebula Device has alerts.
• Red: The Nebula Device is offline.
• Gray: The Nebula Device has been offline for 7 days or more.
Device type
This shows the type of the Nebula Device.
Model
Tag
This shows the tag created and added to the Nebula Device.
Name
MAC address
S/N
Site
Current version
This shows the version number of the firmware the Nebula Device is currently running. It shows N/A when the Nebula Device goes offline and its firmware version is not available.
Firmware status
The status shows Good if the Nebula Device is running a stable firmware and no immediate action is required. See the description of a stable firmware on the next field Firmware type.
The status shows Warning if a newer firmware is available and immediate action is recommended. The newer firmware may contain security enhancements, new features, and performance improvements.
The status shows Critical if a newer firmware is available and immediate action is required. The firmware may have security vulnerabilities and/or lack key performance improvements.
The status shows Custom if the Nebula Device is running a firmware with specialized features that is not available to the general public.
The status changes to Upgrading... after you click Upgrade Now to install the firmware immediately.
Firmware type
This shows Stable when the installed firmware may not have the latest features but has passed Zyxel internal and external testing.
This shows Latest when the installed firmware is the most recent release with the latest features, improvements, and bug fixes.
This shows General Availability when the installed firmware is a release before Latest, but is still undergoing Zyxel external testing.
This shows Dedicated when the installed firmware is locked and Zyxel support is monitoring. Contact Zyxel customer support if you want to unlock the firmware in order to upgrade to a later one.
This shows Beta when the installed firmware is a release version for testing the latest features and is still undergoing Zyxel internal and external testing.
This shows N/A when the Nebula Device is offline and its firmware status is not available.
*See Firmware Type Version Progression Example for an example Firmware type version progression example scenario.
Availability
This shows whether the firmware on the Nebula Device is Up to date, or with a firmware update available for the Nebula Device (Upgrade available), or with a specific version of firmware has been installed by Zyxel customer support (Locked).
Upgrade scheduled
This shows the date and time when a new firmware upgrade is scheduled to occur. Otherwise, it shows Follow upgrade time and the Nebula Device sticks to the site-wide schedule or No when the firmware on the Nebula Device is up-to-date or the Nebula Device goes offline and its firmware status is not available.
A lock icon displays if a specific schedule is created for the Nebula Device, which means the Nebula Device firmware will not be upgraded according to the schedule configured for all Nebula Devices in the site.
Last upgrade time
This shows the last date and time the firmware was upgraded on the Nebula Device.
Schedule upgrade version
This shows the version number of the firmware which is scheduled to be installed.
Firmware Type / Version Progression
The following table shows an example firmware version progression scenario.
version number timeline
firmware type
firmware type
V6
Latest
V5
V7
Latest
V6
*Zyxel will select a previous version, (for example, V3) as a Stable release if no major issues have been reported by users.
There can only be one Latest and one Stable firmware.
Cloud Authentication
Use this screen to view and manage the user accounts which are authenticated using the NCC user database, rather than an external RADIUS server. Click Organization-wide > Organization-wide manage > Cloud authentication to access this screen.
*The changes you made in this screen apply to all sites in the organization. To change the cloud authentication settings for a specific site, go to Site-wide > Configure > Cloud authentication (see Configure).
*The settings in this screen will not apply to Security Firewall(s) in Cloud Monitoring mode.
User Account Types
NCC has the following types of user accounts. For details on using these accounts for WiFi and network authentication, see SSID Advanced Settings.
Cloud Authentication: User Account Types
Account Type
Description
Authentication Methods
User
The user account can gain access to the networks by authenticating using a pre-created user name and password, or their email address.
This type of user account also supports DPPSK and two-factor authentication.
• WiFi authentication (WPA-Enterprise)
• Network access through captive portal
• VPN Access
• WiFi authentication + network authentication through DPPSK
MAC
The Nebula Device account that can gain access to the networks by authenticating using its MAC address.
• MAC-based Nebula Device authentication (combined with DPPSK)
DPPSK
A user that can gain access to the network using a unique dynamic Personal Pre-Shared key that is linked to their user account.
Cloud Authentication User Screen
Use this screen to view and manage regular NCC network user accounts. Click Organization-wide > Organization-wide manage > Cloud authentication > User to access this screen.
*Some of the actions on this screen are only available if your administrator account has full access to the organization.
Label
Description
Authorization
Select one or more than one user account and click this button to configure the authorization settings for the selected user accounts.
Remove users
Select one or more than one user account and click this button to remove the selected user accounts.
VPN access
Select one or more than one user account and click this button to configure whether the accounts can be used to connect to the organization’s networks through VPN.
VLAN attribute
Select one or more than one user account and click this button to assign the users to a specific VLAN ID, or clear the VLAN ID. Then click Update.
Print
Click this button to print information about each selected user account, such as their user name and password.
Search users
Enter a key word as the filter criteria to filter the list of user accounts.
N User
This shows how many user accounts (N) match the filter criteria and how many user accounts of the selected type are created in total.
Import
Click this button to create user accounts in bulk by importing a complete list of all new users in an Excel file.
Add
Click this button to create a new user account. See Create/Update User Account.
Export
Click this button to save the account list as a CSV or XML file to your computer.
Email
This shows the email address of the user account.
Username
This shows the user name of the user account.
Description
This shows the descriptive name of the user account.
802.1X
This shows whether 802.1X (WPA-Enterprise) authentication is enabled on the account.
VPN access
This shows whether the accounts can be used to connect to the organization’s networks through VPN.
Authorized
This shows whether the user has been authorized or not (No). If the user is authorized, it shows All sites or the name of the site to which the user is allowed access.
Expire in (UTC)
This shows the date and time that the account expires.
This shows -- if authentication is disabled for this account.
This shows Never if the account never expires.
This shows Multiple value if the account has different Expire in values across different sites.
Login by
This shows whether the user needs to log in with the email address and/or user name.
DPPSK
This shows the account’s dynamic personal pre-shared key (DPPSK), if one is set.
VLAN assignment
This field is available only when the account type is set to User.
This shows the VLAN assigned to the user.
2FA Status
This shows whether the account has set up two-factor authentication yet.
Bypass 2FA
This shows whether the account is allowed to bypass two-factor authentication, if two-factor authentication is enabled on a captive portal or VPN gateway.
Authorized by
This shows the email address of the administrator account that authorized the user.
If the account has been authorized by different admins across different sites, it shows Multiple value.
Created by
This shows the email address of the administrator account that created the user.
Created at
This shows the date and time that the account was created.
In the Site-wide or Organization-wide > Organization-wide manage > Cloud authentication > User screen, click the Add button to create a new user account or double-click an existing account entry to modify the account settings.
Organization-wide > Organization-wide manage > Cloud authentication > User: Create/Update user
Label
Description
Account type
This shows the type of the user account.
Email
Enter the email address of the user account, which is used to log into the networks.
Username
Enter a user name for this account.
*This field is optional if Login by is set to Email.
Description
Enter a descriptive name for the account.
Password
Enter the password of this user account. It can consist of 4 – 31 alphanumeric characters.
You can click Generate to have NCC create a password for the account automatically.
DPPSK
Enter a dynamic personal pre-shared key (DPPSK) for this DPPSK user account, if you want to be able to authenticate using DPPSK in addition to a user name and password. It can consist of 8 – 31 alphanumeric characters.
You can click Generate to have the NCC create a DPPSK for the account automatically.
802.1X
Select this to allow the account to be used for single sign-on (SSO) network and WiFi authentication using 802.1X (WPA-Enterprise).
VPN Access
Select this to allow the account to be used to connect to the organization’s networks through VPN.
Authorized
Set whether you want to authorize the user of this account.
You can select to authorize the user’s access to All Sites or Specified Sites in the organization. If you select Specified Sites, a field displays allowing you to specify the sites to which the user access is authorized.
Expire in
This field is available only when the user is authorized.
Click Change to specify the number of minutes/hours/days/weeks the user can be logged into the network in one session before the user of this account has to log in again.
*If the account has been set with different Expire in values across different sites, it will show Multiple value and the Change link.
Otherwise, select Never and the user of this account will never be logged out.
Login by
Select whether the user needs to log in with the email address and/or user name.
VLAN assignment
This allows you to assign a user to a specific VLAN based on the user credentials instead of using a RADIUS server.
Bypass two-factor authentication
Email account information to user
Select this to send a copy of the information on this screen to the account email address, after the account has been created.
Close
Click this button to exit this screen without saving.
Print
Click this button to print the account information.
Create user
Click this button to save your changes and close the screen.
Cloud Authentication MAC Screen
Use this screen to view and manage NCC Nebula Device user accounts, used for MAC-based authorization. Click Organization-wide > Organization-wide manage > Cloud authentication > MAC to access this screen.
Label
Description
Authorization
Select one or more than one account and click this button to configure the authorization settings for the selected user accounts.
Remove users
Search users
N User
Import
Add
Click this button to create a new user account. See Create/Update MAC Account.
Export
Email
MAC address
This shows the MAC address of the user account.
Description
Account type
This shows the type of user account: USER, MAC, or DPPSK.
Authorized
Authorized by
Expire in (UTC)
Created at
In the Site-wide or Organization-wide > Organization-wide manage > Cloud authentication > MAC screen, click the Add button to create a new user account or double-click an existing account entry to modify the account settings.
Organization-wide > Organization-wide manage > Cloud authentication > MAC: Create/Update user
Label
Description
Account type
Description
MAC address
Enter a MAC address for this account.
Authorized
Set whether you want to allow the user of this account access to sites.
Select All Sites or Specified sites to allow the user access to all or some sites in the organization. If you select Specified sites, a field displays allowing you to specify the sites to which the user access is authorized.
Select Not authorized to prevent the user access to all the sites in the organization.
Expires
Specify the number of minutes/hours/days/weeks the user has access to site(s) in the organization.
Close
Print
Create user
Cloud Authentication DPPSK Screen
Use this screen to view and manage DPPSK network user accounts. Click Organization-wide > Organization-wide manage > Cloud authentication > DPPSK to access this screen.
Label
Description
Authorization
Remove users
Print
Click this button to print the unique dynamic personal pre-shared key (DPPSK) and expiry time of each selected user account.
The account details can be cut into cards, and then given to users in order to grant them WiFi network access.
Search users
N Users
Import
Add
Click this button to create a single new account, or a batch of accounts.
• Single DPPSK: See Add/Edit DPPSK Account.
• Batch create DPPSK: See Batch Create DPPSK Accounts.
Export
Email
Username
Account type
DPPSK
This shows the account’s dynamic personal pre-shared key (DPPSK).
VLAN ID
This shows the VLAN assigned to the account.
Description
Authorized
Expire in (UTC)
Created by
Created at
In the Site-wide or Organization-wide > Organization-wide manage > Cloud authentication > DPPSK screen, click Add > Single DPPSK to create a new user account or double-click an existing account entry to modify the account settings.
Organization-wide > Organization-wide manage > Cloud authentication > DPPSK: Create/Update DPPSK user
Label
Description
Account type
Email
Username
Description
DPPSK
Enter a dynamic personal pre-shared key (DPPSK) for this DPPSK user account. It can consist of 8 – 31 alphanumeric characters.
VLAN id
Enter the ID of a VLAN to assign a user to a specific VLAN.
Authorized
Expire in
Close
Print
Create user
To have NCC create multiple DPPSK user accounts, each with a unique dynamic personal pre-shared key (DPPSK), go to the Site-wide or Organization-wide > Organization-wide manage > Cloud authentication > DPPSK screen, click Add, and then select Batch Create DPPSK.
Organization-wide > Organization-wide manage > Cloud authentication: Batch Create DPPSK
Label
Description
Number of accounts
Enter how many DPPSK user accounts you want to create.
VLAN id
Assign the users to a specific VLAN based on the user’s dynamic personal pre-shared key (DPPSK).
E-mail account info to
Send a copy of each user account’s dynamic personal pre-shared key (DPPSK) and expiry date to the specified email address. This information is in a printable format.
The expiry date includes a time and date in UTC format.
Authorized
Expire in
Close
Create user
Change Log
Use this screen to view logged messages for changes in the specified organization. Click Organization-wide > Organization-wide manage > Change log to access this screen.
When the log is full, it deletes older entries one by one to make room for new ones.
Label
Description
Search
Click to enter one or more key words as the search criteria to filter the list of logs.
Range/Before
Select Range to set a time range or select Before to choose a specific date/time and the number of hours/minutes to display only the log messages generated within a certain period of time (before the specified date/time). The maximum allowable time range is 30 days.
Search
Click this to update the list of logs based on the search criteria.
Reset filters
Click this to return the search criteria to the previously saved time setting.
Newer/Older
Click to view a list of log messages with the most recent or oldest message displayed first.
This shows the total number of the log messages that match the search criteria. It also shows the date and time the very first log was created.
Export
Click this button to save the log list as a CSV or XML file to your computer.
Time (UTC)
This shows the date and time in UTC+00:00 (or UTC+0) when the log was recorded.
UTC is a standard time for use around the world (formerly known as Greenwich Mean Time or GMT). UTC is an international abbreviation that is neither French nor English. It means both "Temps Universel Coordonné" and "Coordinated Universal Time".
Site Time
This shows the date and time of the site, to which the change was applied, when the log was recorded.
Admin
This shows the name of the administrator who made the changes.
Site
This shows the name of the site to which the change was applied.
SSID
This shows the SSID name to which the change was applied.
Page
This shows the name of the NCC menu in which the change was made.
Label
This shows the reason for the log.
Old value
This shows the old setting that was discarded and overwritten with the new attribute value.
New value
This shows the new setting that was adopted.
Organization Settings
Use this screen to change your general organization settings, such as the organization name and security. Click Organization-wide > Organization-wide manage > Organization settings to access this screen.
Label
Description
Organization information
Name
Enter a descriptive name for the organization.
Country
Select the country where the organization is located.
*This field is only for reference. It does not affect any other fields or features in NCC.
MSP ID
Enter the customer ID used by the administrator of the organization on another system. For example, CRM (Customer Relationship Management) and ERP (Enterprise Resource Planning) systems.
*You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 64 characters.
Notes
Enter the user-specified description of the MSP ID.
*You can use alphanumeric and ()+/:=?!*#@$_%- characters, and it can be up to 256 characters.
Cloud Monitoring Mode ID
To allow NCC to monitor your on premise Security Firewall, select Cloud Monitoring Mode on the Web Configurator of the Security Firewall. See the Security Firewall’s User’s Guide for more information.
Click the copy icon to copy and paste the Cloud Monitoring mode ID into the Configuration > Mgmt. & Analytics > Nebula > Cloud Monitoring Mode.
Generate
The Cloud Monitoring mode ID is composed of 24 random alphanumeric characters. Click this button to have NCC create a new Cloud Monitoring mode ID.
Security
Idle timeout
Select ON and enter the number of minutes each user can be logged in and idle before the NCC automatically logs out the user.
Select OFF if you do not want the NCC to log out idle users.
Two-factor authentication
Select ON to enable two-factor authentication login for all administrators of this organization.
*If this option is unavailable, you must enable Two-factor authentication in Account > Manage account, log out of NCC, and then log in again before you can enable organization-wide two-factor authentication in this screen.
The following administrators will be forcibly log out and prevented from logging in after enabling this option:
• administrators using Google/Apple Accounts to login, and
• administrators who did not enable Two-factor authentication in the Account > Manage account.
*Two-factor authentication is mandatory but unavailable for administrators using Google/Apple Accounts for login. Administrators using Google/Apple Account for login must contact customer support to change their login email address.
Login IP ranges
Select ON and specify the IP address range of the computers from which an administrator is allowed to log into the NCC.
Select OFF to allow any IP address of the computer from which an administrator can log into the NCC.
Import certificate
Use my certificate
Select ON to import a certificate that can be used by connected Nebula Access Points in WPA2 authentication.
Name
Enter a name for the certificate (up to 64 letters).
File Path
Click to find the certificate file you want to upload.
Import
Click this button to save a new certificate to the NCC.
Password
Enter the certificate file’s password.
Device ownership takeover
By default, your Nebula Device can transfer to another administrator’s organization by using the Nebula Mobile app to scan the QR code. Click this switch to the right to prohibit Nebula Device transfer between administrators.
Paid features indicator
Select ON to show the diamond indicator for NCC features that require a license to unlock.
Delete this organization
Click the Delete organization button to remove the organization when it does not have any sites, Nebula Devices or users.
*You will be redirected to the Choose organization page after this organization is deleted.
