Troubleshooting
This chapter offers some suggestions to solve problems you might encounter with NCC and Nebula Devices.
• To see how to do things in NCC, go to the Tutorials section.
• To know how to manage Mobile Routers in NCC, go to Configuration for more information.
• To know how to monitor Security Appliances in NCC, go to Monitor (Security Firewalls) or Monitor (Security Gateways) for more information.
• To know how to configure Security Appliances in NCC, go to Configure (Security Firewalls) or Configure (Security Gateways) for more information.
• To know how to monitor Switches in NCC, go to Monitor for more information.
• To know how to configure Switches in NCC, go to Configure for more information.
• To know how to monitor Access Points in NCC, go to Monitor for more information.
• To know how to configure Access Points in NCC, go to Configure for more information.
I cannot register the Zyxel Device in NCC.
Check if your Zyxel Device supports Nebula by locating the Nebula QR code on the Zyxel Device label or package box.
I cannot access the NCC portal.
• Check that you are using the correct URL:
• NCC: https://nebula.zyxel.com/
• Make sure your computer’s Ethernet card is installed and functioning properly.
• Check that you have Internet access. In your computer, click Start, (All) Programs, Accessories and then Command Prompt. In the Command Prompt window, type ‘ping’ followed by a website such as ‘zyxel.com’. If you get a reply, try to ping ‘nebula.zyxel.com’.
• Make sure you are using the correct web browser that supports HTML5. View the browser in full screen mode to display the NCC portal properly. Browsers supported are:
• Google Chrome
• Microsoft Edge
• Mozilla Firefox
I cannot log into the NCC portal.
Open your web browser and go to https://nebula.zyxel.com. Sign in with the correct email and password. Click Sign Up if you do not have a Zyxel Account and create an account.
I cannot access a Nebula Device that I have registered in NCC or the Nebula Device appears offline in NCC.
• Check if the TCP/UDP port is blocked by your network’s firewall rule or ISP. Click Help > Support tools > Firewall information to view information required for firewall rules to allow management traffic between NCC and Nebula Devices on your sites.
• Check the Nebula Device’s hardware connections, and make sure the LEDs are behaving as expected. See the Quick Start Guide.
• If the LEDs still do not turn on, you may have a hardware problem. In this case, you should contact your local customer support.
• Make sure the Nebula Device is connected to the Internet.
• For Mobile Routers, make sure a valid SIM card is inserted in the SIM card slot.
• Make sure the Mobile Router is located where the cellular signal is strong.
• For ZyWALL USG FLEX / ATP / USG20(W)-VPN Series devices with Nebula native mode as the deployment method, make sure you perform the steps for Nebula native mode on the Nebula Device; see Nebula Native Mode for information.
If you select Zero Touch Provision mode as the deployment method. Make sure you perform the steps for Zero Touch Provision mode on the Nebula Device, see Zero Touch Provision Mode for information.
• Check if the WAN IP address is configured on the Nebula Device.
• Check if the Nebula Device can access the NCC server’s domain through SSH/Console and enter ‘nslookup d.nebula.zyxel.com’. If the Nebula Device shows ‘unknown host’, check your DNS server setting or use ‘8.8.8.8’ as the DNS server on the Nebula Device.
• The Nebula Devices will apply the site-wide password after getting online on NCC. Check the login credential by going to Site-wide > Configure > Site settings: Local credentials.
• Specify the Port number and click Establish using Remote Access in the following screens to obtain real-time logs and data from the Nebula Device.
• Site-wide > Devices > Access points
• Site-wide > Devices > Security router
• Site-wide > Devices > Firewall
• Site-wide > Devices > Security gateway
*Remote Access to Nebula Access Points is available to the organization owner, organization administrators with full privileges, and site administrators with full privileges in Nebula Pro Pack license only.
Remote Access to Nebula Security Firewalls and Security Gateways is available to the organization owner in Nebula Pro Pack license only.
• Make sure that your Nebula Device can connect to the NCC by checking your network’s firewall/security settings. The following ports must be allowed:
• TCP: 22, 443, 4335 and 6667
*Go to Help > Support tools > Firewall information to find the latest port information.
• Make sure that your Nebula Device can synchronize with NTP (Network Time Protocol) through the following port:
• UDP: 123
• Make sure that your Nebula Device can resolve the Nebula Cloud Management (NETCONF) domain name d.nebula.zyxel.com.
• Changing the MTU (Maximum Transmission Unit) size in Site-wide > Configure > Firewall > Interface > WAN/LAN interface configuration may cause the Nebula Switches to appear offline. Make sure that the MTU size is not smaller than 1500 bytes.
I cannot see my Nebula Devices in the NCC Dashboard or the corresponding Nebula Device monitor page.
• Check the Nebula Device’s local Web Configurator’s Dashboard. The Cloud Control Status displays the status of the Nebula Device’s Internet and NCC connection and registration status. Make sure that the Nebula Device has NCC Discovery enabled.
• If the Nebula Device cannot connect to the Internet or NCC, hover the mouse over the Internet circle to check the error message. Check your local network settings.
• UDP: 123
• Make sure that you have registered your Nebula Devices with the NCC. See License & Inventory Overview Screen.
• Make sure that you have created an organization and site and added the Nebula Devices to the site. See Create Organization .
• When the Nebula Device is online in NCC, all circles are green.
I made the mistake of assigning a license to a Nebula Device and the license is in Active/Queued status. Can I Undo assign?
No, Undo assign can only apply to an Inactive license. Select Transfer license to transfer the license to the correct Nebula Device.
I have already transferred a license to a Nebula Device. Why is the organization still in the grace period or Base tier?
Not all Nebula Devices in the organization have been assigned a license. Check if you have assigned a valid Plus or Professional license to all unlicensed Nebula Devices in the organization.
• In Organization-wide > License & inventory > Overview, click Upgrade Now to upgrade the organization to Plus or Professional tier.
• Alternatively, remove the unlicensed Nebula Device(s) from the organization.
My organization is now in Cloud-saving mode; how can I disable it?
There are two ways to disable Cloud-saving mode.
• Click the Cloud-saving mode switch in the Welcome back pop-up window.
Then click Close to turn off Cloud-saving mode for the organization.
• A banner displays when NCC is in Cloud-saving mode.
Click the You could change mode here link in the NCC banner.
Click the Cloud-saving mode switch in the Cloud-saving mode pop-up window.
I want to place my Nebula Device on the right location on Google maps.
If your Nebula Device has a public IPv4 address, Google Maps can use Geo IP to approximatively locate your Nebula Device. If your Nebula Device has an IPv6 address or a private IPv4 address or you want locate the Nebula Device more exactly, use one of the following methods.
• Select Use the following address or coordinates to enter the complete address or coordinates of the Nebula Device in Site-wide > Devices > Firewall / Security gateway / Switches / Access points: details: Map: Position device.
• Select Get my location from web browser to use the public IP address of the computer accessing the NCC portal.
• Drag-and-drop your Nebula Device directly on the Google map.
I cannot set up Secure WiFi in NCC.
• Make sure the Nebula Security Firewall and Nebula Access points are in the same NCC site.
• Make sure a Secure WiFi license is assigned to the Nebula Security Firewall.
• Make sure to configure the Remote AP Setting of each Remote Access Point before booting up the Remote Access Point in the remote site. See Site-wide > Devices > Access points: Details.
• The maximum number of Remote Access points depends on the Nebula Security Firewall.
Maximum Remote Access Points (at the time of writing)
capacity
usg flex 50 / USG20-VPN / USG20W-VPN
usg flex 100 / usg flex 100w / atp100 / atp100w
usg flex 200 / ATP200
usg flex 500 / ATP500
ATP700
usg flex 700 / ATP800
Maximum IPSec Tunnel
10
40
90
250
450
450
Maximum Remote AP
No support
6
10
18
66
130
The mesh extender does not appear online on Status in Site-wide > Devices > Access points.
• Click Reconnect in Site-wide > Devices > Access points: Uplink AP to re-establish connection.
• Make sure your Nebula Device supports smart mesh. To view the list of Nebula Devices that support smart mesh, go to Help > Device function table.
After adding a mesh extender to a site, the mesh extender cannot connect to a mesh controller.
• Make sure you enable AP Smart Mesh in Site-wide > Configure > Access points > AP & port settings. See AP & Port Settings for more information.
*For more information about smart mesh, see Nebula Smart Mesh.
The mesh extender does not broadcast the mesh controller SSID.
• Make sure you enable Downlink in Site-wide > Devices > Access points: Details. See Access Point Details for more information.
• To enhance your mesh extender’s connectivity, maintain an Uplink signal strength above -65 dBm. You can check this in Site-wide > Devices > Access points.
None of the Nebula Device LEDs turn on.
• Make sure that you have the power cord connected to the Nebula Device and plugged in to an appropriate power source. Make sure you have the Nebula Device turned on.
• Check all cable connections. See the related Quick Start Guide.
The Nebula Device PWR LED is red.
• The Nebula Device has a power-related error. Disconnect and reconnect the power cord. Make sure that you are using the included power cord for the Nebula Device and it is plugged into an appropriate power source. See the related Quick Start Guide.
• If the LED is still red, you may have a hardware problem. In this case, you should contact your local customer support.
I need to replace a defective Nebula Device on my stacking system. I want to keep the NCC configurations.
• Contact your vendor about the faulty Nebula Device.
• Do NOT remove or swap the faulty Nebula Device in NCC.
• Contact Zyxel Customer Support to keep the faulty Nebula Device’s port configuration and apply it to the new Nebula Device.
When I click Upgrade now in the Site-wide > Configure > Firmware management or Organization-wide > Organization-wide manage > Firmware management screens, I get an Upgrade system firmware failed.
• Make sure the DNS server used by your Nebula Device can resolve the domain name ‘firmware.nebula.zyxel.com’.
• Make sure there are no firewall policies restricting access to ‘firmware.nebula.zyxel.com’ and that the firewall allows connection to TCP port 443.
• If there is no firewall policy restricting access, log in to the Nebula Device Web Configurator to get the technical support log from the following location:
• For an Access Point, go to MAINTENANCE > Diagnostics > Diagnostic > Collect now.
• For a Switch, go to MAINTENANCE > Tech-Support > All.
• For a Security Router, there is no technical support log.
• For a Security Firewall, go to MAINTENANCE > Diagnostics Info > Collect now.
• For a Security Gateway, go to MAINTENANCE > Diagnostics > Collect > Collect now > Files.
• For a Mobile Router, there is no technical support log.
• Contact Zyxel Customer Support for help.
*The Upgrade now option is available only when the selected Nebula Devices have a new firmware available.
The smartphone app cannot find and communicate with the IoT (Internet of Thing) device over WiFi.
• Go to Site-wide > Configure > WiFi SSID settings to configure a separate WiFi network for the IoT device(s).
• Go to Site-wide > Configure > Access points > SSID advanced settings and select the separate WiFi network in the previous step. Select WPA Personal With WPA2 in Security options.
• Select the 2.4GHz band in Band mode. The smartphone with IoT app and IoT device must connect to an SSID on the 2.4 GHz band. This enhances the connectivity and performance of IoT devices.
• Disable 802.11k/v/r in Assisted roaming and 802.11r. This prevents the Nebula Device from steering IoT devices to the 5 GHz band.
• Disable Layer 2 isolation in Advanced settings. An IoT device's MAC address that is not in the Layer 2 isolation table will not be able to communicate with other devices in the same WiFi network when layer-2 isolation is enabled.
*When layer-2 isolation is enabled, click Add to enter a MAC address of a IoT device you want to allow access to other devices in the same WiFi network.
• Disable Intra-BSS traffic blocking in Advanced settings. This allows direct communication between IoT devices from within the same WiFi network.
• Go to Site-wide > Configure > WiFi SSID settings. Configure the same Tagging for the same WiFi network and the Tag for the Nebula Device in Site-wide > Devices > Access points. For example, tagging Nebula Device A with "Lobby" in Site-wide > Devices > Access points and assigning the "Lobby" tag to "SSID_lobby" in Site-wide > Configure > WiFi SSID settings means that Nebula Device A will broadcast "SSID_lobby."
• Go to Site-wide > Configure > Radio settings and disable Allow 802.11ax/ac/n stations only. This allows the IEEE 802.11a/b/g IoT devices to connect.
A WiFi client device cannot connect to a Nebula Device WiFi.
• Check the WiFi LED status to make sure the Nebula Device WiFi is on.
• Make sure the WiFi client is within transmission range of a Nebula Device.
• Make sure the WiFi client entered the correct SSID (Service Set IDentifier) and pre-shared key (PSK). Go to Site-wide > Configure > WiFi SSID settings for the correct SSID and PSK.
• Make sure your WiFi client is using the same WiFi security type (PSK or open) as the Nebula Device.
• Make sure the WiFi adapter on your WiFi client is working. Right-click your WiFi client computer's network adapter and then select Properties to check the network adapter status.
• Make sure the WiFi adapter on your WiFi client is IEEE 802.11-compatible. Make sure it supports the same WiFi standard as the Nebula Device 2.4G/5G radio.
• Select MAC authentication fallback in Site-wide > Configure > Access points > SSID advanced settings: Sign-in method. If MAC authentication fails, the WiFi client will use web authentication with a user name and password.
Example Scenario: When MAC authentication fails.
A WiFi client tries to connect to a WiFi network using MAC authentication (RADIUS server). If MAC authentication fails, the WiFi client will fall back to web authentication. The WiFi client must provide a user name and password for web authentication.
A client device’s WiFi connection is slow and intermittent.
The following factors may cause interference:
• Obstacles: walls, ceilings, furniture, and so on.
• Building Materials: metal doors, aluminum studs.
• Electrical devices: microwaves, monitors, electric motors, cordless phones, and other WiFi devices.
To optimize the speed and quality of a WiFi connection, you can:
• Move the client WiFi device closer to a Nebula Device if the signal strength is low.
• Reduce WiFi interference caused by other WiFi networks or surrounding wireless electronics such as cordless phones.
• Reduce the number of WiFi clients connecting to the same Nebula Device simultaneously, or add additional Nebula Devices if necessary.
• Try closing some programs that use the Internet on the WiFi client, especially peer-to-peer applications. If a WiFi client is sending or receiving a lot of information, it may have too many programs open that use the Internet.
• Place a Nebula Device where there are minimum obstacles (such as walls and ceilings) between a Nebula Device and a WiFi client. Avoid placing a Nebula Device inside any box that might block WiFi signals. See How to Position Multiple Nebula Devices (for Nebula Access Points only) for more tips on selecting the best position to minimize signal interference for multiple Nebula Devices (access points).
• Go to Site-wide > Configure > Access points > SSID advanced settings: Advanced settings and turn on IEEE 802.11r fast roaming on the Nebula Device. 802.11r fast roaming reduces the delay when the clients switch from one Nebula Device to another by storing the security keys on all Nebula Devices in a network. Information from an original association is passed to the new Nebula Device when the clients roam. The clients do not need to perform the 802.1x authentication process again.
I enabled AP traffic log in Site-wide > Configure > Site settings: Reporting, and I want to restrict the type of logs from my Nebula Device (for example, no debug logs).
• At the time of writing, Nebula Devices will log all events. You will not be able to restrict the type of logs written.
• You can choose the type of logs to generate only in Standalone mode by doing the following:
• Log in to the Nebula Access Point’s Web Configurator.
*If NCC is managing or has managed a Nebula Device, check Local credentials in Site-wide > Configure > Site settings for the Nebula Device’s current password.
• Go to Configuration > Log & Report > Log Setting > Active Log Summary.
• Select what information to include in the system log.
My Mac OS computer will not display the captive portal page for logging in.
• Enter “http://neverssl.com” in the Location or Address field of your browser. This allows you to access the NCC login page by bypassing SSL (Secure Sockets Layer). SSL creates an encrypted link between a web server and a web browser.
I am unable to access a Nebula Device in Standalone mode after removing (unregistering) the Nebula Device from NCC.
• Make sure the Nebula Device has been removed from your organization. Go to Organization-wide > License & inventory > Devices. Select the Nebula Device, click Actions, then click Remove from organization. Click Yes to confirm, or click the delete icon to remove the Nebula Device.
• Make sure to reset the Zyxel Device to its factory-default settings. This will remove the current configuration.
You should now be able to access the Zyxel Device’s Web Configurator in Standalone mode.
Getting More Troubleshooting Help
Go to support.zyxel.com at the Zyxel website for other technical information on the NCC.
NCC Live Chat
Clicking the Ask Question button at the bottom of NCC window prompts you to search for a solution on the Zyxel forum, and then connects you to a Zyxel technical support agent. If a technical support agent is not available, you can fill in a form to send your question to Zyxel by email.
*This is an NCC Professional Pack feature.
Live chat might be limited to a certain number of hours per day. The time that live chat is available varies depending on your country.
