Tutorials
Overview
This chapter shows you how to use the NCC’s various features.
Add a Nebula Device
Activate and Assign a License for a Nebula Device, Site, or Organization
Monitor a Site
Know What Licenses are Set to Expire in My Site or Organization
Renew an Expired License
Transfer Licenses
Change an Organization and/or Site Name
Reset the Nebula Password
Maintain Firmware
Backup Current Configurations in NCC
Assign an Administrator to Manage a Nebula Device
Transfer the Ownership of the Organization
Manage a Configuration Template
Activate an MSP License
Configure CNP/CNP Plus Security Services
Delete an Organization
Remote Access VPN Setup
Route L2TP VPN Traffic
Configure Guest Isolation on your WiFi Network
Configure Content Filter to Block Access to Certain Websites
Configure Schedule to Allow WiFi Access Only at Certain Times
How to Position Multiple Nebula Devices (for Nebula Access Points only)
Change the Default SSID and Password
Change the WiFi Band Mode
Check What Clients are Connected to Nebula Devices in your Network
Find the SSID of the WiFi Client (for Nebula Access Points only)
Use Tags to Assign SSIDs for Nebula Devices (for Nebula Access Points only)
Resolve WiFi Connection Problems (for Nebula Access Points only)
Configure WiFi Security with WPA2 Personal (for Nebula Access Points only)
Configure WiFi Security with WPA2 Enterprise (for Nebula Access Points only)
Configure a Captive Portal
Create a Custom Captive Portal Page
Limit Applications Usage or Block Applications
Find the LAN Port Used by Connected Wired Client Devices (for Nebula Switches only)
Configure Voice VLAN (for Nebula Switches only)
Manage IPTV (for Nebula Switches only)
Enable IP Source Guard (for Nebula Switches only)
Set Up MAC Authentication With NCAS (for Nebula Switches only)
Set Up Dynamic VLAN With RADIUS (for Nebula Switches only)
Monitor Dynamic VLAN Using Event Logs (for Nebula Switches only)
Register a Nebula Device (mobile router) in Nebula
Using Collaborative Detection and Response (CDR)
Deploy With Nebula Native Mode (for Security Firewalls in Nebula only)
Configure DHCP Domain Name (for Security Firewalls in Nebula only)
Monitor Client Bandwidth Usage (for Security Firewalls in Nebula only)
Configure a Primary and Backup WAN (for Security Firewalls in NCC only)
Enable Smart Mesh on a Security Router
This site works best with JavaScript enabled
